Quantcast Fan Relay, How Do I Change This? - JeepForum.com
Jeep Home Jeep Forum Jeep Classifieds Jeep Registry JeepSpace Jeep Reviews Jeep Gallery Jeep Blogs Jeep Clubs Jeep Groups Jeep Videos Jeep Events Jeep Articles
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Fan Relay, How Do I Change This?
Trail Canvas Seat Covers & Smittybilt G.E.A.R. Covers Free Shipping on all Engo Winches Continues...starting at Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
JeepForum Membership Drive - Reduced Premium Membership For a Short Time Only
Old 09-04-2010, 06:02 PM   #1
superman1981
Last night I came home, and the radiator fan on my 2001 Grand Cherokee Limited wouldn't turn off. After 30 mins or so, I pulled the fuse.
This morning I replaced the fuse, started up the Jeep, and now I'm having the opposite problem, the fan won't come on.
I've read several threads, and it looks like I'm going to be spending Labor Day changing the Fan Relay.
My auto-repair knowledge is fairly limited, so if someone could point me to a thread or tutorial on how to change out a fan relay, it would be greatly appreciated!
Thanks in advance,
-Tim
superman1981 is offline   Reply With Quote
Old 09-04-2010, 07:53 PM   #2
StrokedWJ
I think this is what you're looking for...JeepsLimited.com - Fan Relay Removal and Replacement (WJ)
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Click this -->Think you can beat me?
StrokedWJ is offline   Reply With Quote
Old 09-04-2010, 08:28 PM   #3
superman1981
Thanks for the replies!
StokedWJ, that link is exactly what I'm looking for. Now that I have a visual, I'm ready to go. I'm planning on cutting the plastic with a rotary tool, does anybody have recommendations for me? I really don't want to hit anything important.
Old 09-05-2010, 05:48 PM   #4
byteHeed
If you cut the plastic under the headlight, just don't go too deep... there's nothing in that little box other than the relay itself, if I recall.
Use a rotary too with a cord! All I have is a battery powered one and it was a pain because it just doesn't have enough torque.
99 WJ, tow package and a few parts
byteHeed is offline   Reply With Quote
Old 09-05-2010, 08:06 PM   #5
RootJ
Don't replace that stupid relay! Get a mechanical fan from a 98 grand cherokee!
I replaced that $65 part twice by removing the passenger side headlight then using a dremel to cut down through the plastic. Removibg the bumper cover and bumper is not worth it. Just get the blades and cowel from a 98 like I said. It fits and that is one less poorly made part to worry about.
RootJ is offline   Reply With Quote
Old 09-05-2010, 08:11 PM   #6
nitecop
I bought the OEM part for $38?? I think a few years ago on Fleabay. I know it was less then $40. Not hard to do. Make sure you use plenty of heat sink compound on the bottom surface of the module.
Jim
United Steelworkers Union member
99 TJ Sahara 4.0 5-Sp FUV + farm worker
Project f-Xj F150/XJ Ford eXtreme jeep combo
06 6 Speed LJ my daily driver.
Colorado Jeep club memeber #505
nitecop is offline   Reply With Quote
Old 09-05-2010, 08:27 PM   #7
myjeeplovesmud
They Call Me "Mud"
myjeeplovesmud's Avatar
wish i could help ya bud, my wj has the fan thats run by the power steering, so i have experience with this. i'm willing to bet that the positive wire is staying "hot" and therefore it kept running... now you changed the fuse and have the opposite problem is boggling my mind
2004 WJ Limited 4.7 H.O
K&N FIPK - Magnaflow Exhaust
17" XD Series Spy Rims- Custom Painted
ZONE 4" Lift With 32" Duratracs
Hella Lighting - Rola Rack - KOR 3/4 Spacers
IRO Sliders - Rusty's Hooks - Cobra CB
MY BUILD THREAD
BAD TO THE BONE ZONE
November 2010 GCOTM
myjeeplovesmud is offline   Reply With Quote
Old 09-05-2010, 09:09 PM   #8
tjkj2002
2002 KJ Liberty
Thanks in advance,
-Tim
I have had one WJ that the PCM ended up being bad,granted most of the time it is the relay but there is that chance the PCM is bad also.The one that had the bad PCM had the same issue,would not turn off so pulled fuse,then put fuse back in(good fuse) the fan would never turn on again even after a relay change(OEM relay also).
tjkj2002 is offline   Reply With Quote
Old 09-06-2010, 09:01 AM   #9
RootJ
Really though, if this one fries too, switch to the mechanical fan. I have no regrets.
Old 09-06-2010, 07:17 PM   #10
thnksno
I don't believe a mechanical fan will 'do it all.' My 4.0 has both and if the mechanical fan was perfect I'd never hear the e-fan? Plus it comes on as soon as the a/c goes on?
thnksno is offline   Reply With Quote
Old 09-06-2010, 07:24 PM   #11
RootJ
Is the fan attatched to the threads on the engine? Both? Really?
Old 09-07-2010, 09:43 AM   #12
thnksno
Yes, both... The mechanical fan is attached to a stud in/on the water pump pulley, it is operated by a thermal viscous coupling --->>> fancy term for little spring winding on the front. lol!
Anyway, it appears there's 3 different setups. 1) just an e-fan 2) e-fan and mech fan 3) mech fan only
However... #3 appears to be the "wits-end" And not likely Chrysler's intention for 'proper' cooling. I say this because they offered the e-fan on every 4.0 WJ, the mechanical fan was added when a tow package was added to list of options.
Again I worry about the #3 option because if it worked, my e-fan should never come on.
Old 09-07-2010, 11:29 AM   #13
xJoshxx
xJoshxx's Avatar
2011 WK
Mechanical fan upgrade. - JeepsUnlimited.com Forums upgrading to a mech fan
Interested in Amsoil? Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 Laredo with ORA1
xJoshxx is offline   Reply With Quote
Old 09-07-2010, 02:52 PM   #14
1AAdam
the 'e-fan' as u call it is actually called the A/C Condenser Cooling Fan and should only come on when u turn on your a/c. like the fan that blows hot air out of the back of a home a/c unit. the mechanical fan is there to cool the engine and the 'e-fan' is there to cool the condenser and prob help out the mechanical fan when the a/c is on. it may be programmed to come on when the a/c isn't on if the mechanical fan isn't doing the job but really i don't think the jeep engineers would have put that much thought into it. my 01 limited has the 4.0L tow package and just the mechanical fan. i wish it had the 'e-fan' too cause it can get SLIGHTLY hotter than normal in Boston traffic on a very hot day with the a/c on. if i was just your average-joe-car-owner i would never notice it and never car about it.
1AAdam is offline   Reply With Quote
Glock Forum
