False Trans Over Temp Light HELP IM STRANDED - JeepForum.com
post #1 of 7 Old 03-31-2010, 09:55 AM Thread Starter
B_palmer22
Hey guys,
Just had my trans replaced at a shop. The shop claims they cant get the trans temp light off even though it Isnt overheating.The Trans over temp light comes on and stays on so it kicks me out of OD. Any way to bypass it? The Jeep is a 99 WJ with an 01-02 motor and the trans they put in was a 99. The trans control module is an 01-02. They have a 99 TCM but it will not take it because of some security code not being right. Anyone have some insight on what needs to happen with the computers? HELLLPPPP IM STRANDED 300 MILES FROM HOME!
02 Grand Cherokee Overland
99 Grand Cherokee Limited 4.0 Quadra trac 2
B_palmer22 is offline
post #2 of 7 Old 03-31-2010, 10:29 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
is this your 4.0? If so, it doesnt have a TCM...
~James
ezflip is offline
post #3 of 7 Old 03-31-2010, 10:31 AM Thread Starter
B_palmer22
Yeah its a 4.0 I guess they swapped the ECU? reguardless, it still wont take. I really dont want to go to the stealership.
post #4 of 7 Old 03-31-2010, 10:45 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
Im pretty sure it is vin specific and will need to be reflashed by a dealer. What is wrong with your current PCM?
Im thinking someone didnt plug something in or there is a bad wire going to the sensor.
I swapped my tranny in 4.0 a few months ago. I had a 2000 and the tranny came out of an 03. I had zero issues.
~James
ezflip is offline
post #5 of 7 Old 03-31-2010, 10:53 AM Thread Starter
B_palmer22
well when the original trans and motor(99) were pulled 100000 miles ago and a 01 or 02 motor were swapped in. They had to change the ECU then to get the trans to work. So the shop now assumed that they need a 99 ECU when they swapped the 99 trans on to the 01-02 motor. They called me because they are clueless.
post #6 of 7 Old 03-31-2010, 11:01 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
they are clueless.
Clearly
The year the ECU was made shouldnt have anything to do with it. As long as it worked before, it should work now. There is something on the tranny itself they are missing.
~James
ezflip is offline
post #7 of 7 Old 03-31-2010, 11:05 AM Thread Starter
B_palmer22
idk this thing is a cluster f*&k. I really need to get this sorted out so i can go home. a 4 day trip has turned into a 8 day trip....
O/D and trans temp light coming on-- is this bad? w00ten WJ Grand Cherokee Forum 17 04-01-2011 08:11 PM
Trans over Temp light come on and P0740 code luigi120 ZJ Grand Cherokee Forum 8 11-26-2010 08:17 AM
Trans Over Temp WK05 WK Grand Cherokee & XK Commander Forum 6 10-03-2009 06:51 PM
2001 WJ Trans Over Temp Light boldknight ZJ Grand Cherokee Forum 4 10-01-2006 05:38 PM
Temp guage false reading mldcaptain ZJ Grand Cherokee Forum 6 05-28-2006 10:10 AM
