Factory fog lights - Page 6 - JeepForum.com
post #76 of 85 Old 08-18-2013, 01:31 PM
99WJ539918
Glad you guys figured it out. My WJ wiring is different that yours, shanezoid. Must be another difference in the '02 - '04 electrical schematics. Congrats on the fogs, they don't do much of anything, but they do make the Jeep look a lot better.
Build Thread
99WJ539918 is offline
post #77 of 85 Old 08-18-2013, 03:53 PM
cykaaro
Change the bulbs to 9005's and they're much better. 25w bulbs I've always found useless.
As for the wire, I'd remove it like it says than just splicing into it, as you're now feeding power into it and you don't know where the power goes to. Just gives piece of mind that it's not going to cause an issue some where.
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #78 of 85 Old 08-18-2013, 10:26 PM Thread Starter
shanezoid
Just get those bulbs at the local parts store?
shanezoid is offline
post #79 of 85 Old 08-18-2013, 10:30 PM
99WJ539918
I have them in there already. They still are useless. Maybe I don't have them positioned correctly... ?
Build Thread
post #80 of 85 Old 08-18-2013, 10:31 PM
99WJ539918
Yeah, they're headlight bulbs. Cheap, too.
Build Thread
post #81 of 85 Old 08-19-2013, 12:21 AM
cykaaro
They light up low and in front of the jeep. I notice it as with the retrofit, it's designed that it doesn't illuminate right in front of the vehicle until several feet out, and they fill in that and then some as they are lower to the ground than regular driving lights, not like a driving light. This will of course be different with halogen stock lights and blend together more. Still have to put my foglight retrofit in, so will see what difference it makes. As well, using 3000k bulbs for them.
cykaaro is offline
post #82 of 85 Old 07-03-2014, 07:28 PM
rsmith0801
Ok, just my 2 pennies. I wanted factory fogs real bad but could not find the oem kit anywhere. I opted for an ebay set that are round led's that are incased in black molding that fits in the factory spots as a factory replacement. All I did to get mine to work was install the headlight/blinker switch with fog switch non auto. I did not care to have the auto headlight feature. I installed the relay for the fogs and tested my factory connection, hidden up front by the frame and voila, they work. I did not have to mess with any blue wires or splice connections or anything.
rsmith0801 is offline
post #83 of 85 Old 07-05-2014, 05:52 PM
CHULOGORDO82
2015 WK
Where is the factory location .. I am wanting to do this as well
Sent from 36000ft crusing at .84Mach using ACARS
CHULOGORDO82 is offline
post #84 of 85 Old 07-06-2014, 09:57 AM
rsmith0801
Read the first few pages of the thread and it explains everything with pics and diagrams. Thats easier than me trying to explain it. I located the wires, plugged the new headlight switch in, installed the relay and everything worked, I have power to the lights.
post #85 of 85 Old 10-21-2014, 01:45 PM
CHULOGORDO82
2015 WK
Originally Posted by Raptor View Post
The OEM fog light wiring harnesses should be clipped into plastic termination plugs mounted under the urethane bumper skin on either side of frame/chassis forward of the front fenders. All WJ's have them. My '02 WJ came w/OEM fogs and auto headlights but also had the termination plastic plugs mounted into the frame just like non fog light equipped WJ's. These were not used as the harness's were plugged into the working fogs.
Look for a two wire male fog light plug inserted into a plastic termination receptacle that is mounted into the frame/chassis that goes nowhere.
Funny I have the auto headlights but no termination plugs or extra wiring .... How ever there is a light blue wire I traced from the fuse box under the steering wheel to the engine compartment which is wrapped up I wonder if that is the switch lead fort he foggers
