Factory fog lights - JeepForum.com
post #1 of 85 Old 04-05-2013, 03:09 PM Thread Starter
shanezoid
Factory fog lights
I have a 02 and have found a doner 99 so what all do I need to take. Im sure it has it all I just want to make sure I get it all. Thanks Shane.
shanezoid is offline
post #2 of 85 Old 04-05-2013, 03:16 PM
BlueWJlaredo
The switch and housings and mounting brackets. And of course new bulbs which are 9005
BlueWJlaredo is offline
post #3 of 85 Old 04-05-2013, 03:18 PM Thread Starter
shanezoid
What about relay and wiring?
post #4 of 85 Old 04-05-2013, 03:23 PM
BlueWJlaredo
Wiring should all ready be there but yes the relay is needed as well does your have auto headlamps or not
post #5 of 85 Old 04-05-2013, 04:16 PM
dwjeep
Edit: I guess I was thinking the 2002 had round but I guess it was only 2004, sorry about that.
dwjeep is offline
post #6 of 85 Old 04-05-2013, 04:20 PM Thread Starter
shanezoid
I dont have auto headlights and th 02 and 99 have the same foglights. Shane.
post #7 of 85 Old 04-05-2013, 04:25 PM
rcwj04
In 2004 they switched to the round headlights, so the '99 fogs will work in your jeep, as said above just make sure you get the switch and all the mounting brackets and you will be good to go
You forget that most members here don't own a crystal ball to tell you exactly what your problem is, specially with bad pictures that don't say/show much of anything... -Jacko84
Just a 19 year old kid with a Jeep, and broke because of it, and loving every moment.
2004 WJ Laredo 4.0 116k
2" BDS coils & Bilstein 5100's | Addco rear swaybar with energy bushings |
K&N FIPK | glasspack | plasti-dipped badges | 17" moabs | HID's, 245/65/17 Cooper Discover AT3 | Rola rack | Fawkes stand alone shackle tabs | Bed lined interior (what a pain that was)
rcwj04 is offline
post #8 of 85 Old 04-05-2013, 07:39 PM Thread Starter
shanezoid
Cool deal I just want to make sure that I get all that I need. Thanks Shane.
post #9 of 85 Old 04-06-2013, 03:35 AM
cykaaro
This should help you with the install and what parts you will need. Make sure you get the light stalk out of the donor vehicle as well as the security/sensor light. The sensor light is needed for the auto light function to work.
Mopar PDF for install: http://www.wjjeeps.com/misc/fog_install.pdf
More info here: http://www.wjjeeps.com/lamps/lampsupgrade.htm#fog
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #10 of 85 Old 04-09-2013, 12:35 PM Thread Starter
shanezoid
The brackets were made into the doner bumper cover which was broken. So how do I get those? Thanks Shane.
post #11 of 85 Old 04-09-2013, 01:20 PM
cykaaro
There's always ways to improvise to get them to work. With my g/f we epoxied them in, and then secured them from behind into the bumper cover.
cykaaro is offline
post #12 of 85 Old 04-09-2013, 02:17 PM Thread Starter
shanezoid
I was thinking about that.
post #13 of 85 Old 04-09-2013, 05:31 PM
cykaaro
Easiest way unless you get the whole bumper cover from a doner vehicle and use that.
cykaaro is offline
post #14 of 85 Old 08-12-2013, 08:33 PM Thread Starter
shanezoid
Finally got my bumper cover but I cant find the wiring. Any suggestions?? Thanks Shane.
post #15 of 85 Old 08-12-2013, 08:51 PM
JimJ_99WJ
Here's a link to a write-up I did about installing fogs in my '99 GC that didn't come with them originally:
http://www.jeepforum.com/forum/f310/...cover-1444713/
.......Jim
JimJ_99WJ is offline
