extremely low mpg? - Page 2 - JeepForum.com
post #16 of 29 Old 02-05-2013, 07:05 PM Thread Starter
braddf
But i was averaging 18-20 mpg for the longest time when i first got it!
braddf is offline
post #17 of 29 Old 02-05-2013, 07:08 PM
WJlover
change your fuel filter, air filter, spark plugs, clean throttle body, use proper air pressure in tires, do a fuel system service at a shop, and remember that bigger tires, lifts and other mods of that nature will bring down your mpg.
unfortunately though, as cars age, their fuel mileage goes down.
WJlover is offline
post #18 of 29 Old 02-05-2013, 07:45 PM
LWelch
99 4.0 -- getting 19.1 mpg
I bought this Jeep GC 2 WD 4.0 not running, built the engine stock, now got about 15,000 miles on engine, jeep has about 200K total. last 2,000 miles w/half interstate at 70 mph cruise/control, rest 5 - 10 miles suburban driving.. I don't think that's bad!! I've learned to coast a lot more, - I don't mean holding up traffic, just drive half block ahead, take foot off when you don't need power. Another thing, I'm using 5-30 oil, I believe that makes a difference. Full hot engine still has just under 50psi at idle. Runs like a dream!! ((My forum registry says XJ, but I thought it was a WJ??
LWelch is offline
post #19 of 29 Old 02-05-2013, 07:50 PM
ZeJokee
Key word is 2wd.
99 WJ Ltd, Blacked out, 4.7L, 242j Swap, 2'' BB, 245/75/16 Kuhmo Venture AT KL78, Flow Master Super 40, MagnaFlow high flow Cat, Akebono caliper upgrade, Addco rear swaybar, Westin brush guard, Moog Super Trail Boss, Rancho RS5000, Rola roof rack with dual kayak J hooks, PAC-AOEM-CHR, Sony Xplod 1200w amp, 2 Sony Xplod 12'' subs, 118,XXX miles (SOLD)
93 ZJ Ltd, Blacked out, 5.2L, Reman 46RH, Reman 242 Swap, 3.5'' IRO + 2" BB, 33x12.50r15 Mud Claw MTX radials, Bushwacker Flares, 216,XXX miles (Still parked in NC)
04 F-350 SD Crew Cab FX4 Lariat, 6.0 PSD SRW, Head studs, AFE Stage 2 SI Pro Guard 7 intake, Blue Spring mod, 150,XXX Miles
ZeJokee is offline
post #20 of 29 Old 02-05-2013, 07:54 PM
SKI_VT
Originally Posted by ZeJokee
Key word is 2wd.
4wd is 2wd unless slip is detected in the front.
The difference it makes under the normal conditions is a spit in the ocean.
4wd is not AWD
"You people make it sound like Claytons are made from gold and unicorn bones while everyone else uses PVC and spaghetti noodles."
"The Great Turtle Race! -> Iceland vs. Bushwhacker! -> Place your bets!"
SKI_VT is offline
post #21 of 29 Old 02-05-2013, 08:12 PM
ZeJokee
He stated 2wd. A 4wd WJ still has the front diff and driveshaft spinning which causes drag therefore lower MPG. A 2wd does not have but the rear end. Thats why the 242 t-case gets no better than the 247.
ZeJokee is offline
post #22 of 29 Old 02-06-2013, 01:51 AM
cmp77
2003 WJ
My I6 gets as of right now 13.3 average and my v8 as of right now reads 12.2 yours sounds good to me
cmp77 is offline
post #23 of 29 Old 02-06-2013, 02:07 AM
bigchevy87
im getting 12.5 in a AWD 4.7L, your doing good but you almost have 100,000miles on it so do a service like alot of people are saying to do
bigchevy87 is offline
post #24 of 29 Old 02-06-2013, 02:28 AM
JeepFireman304
My 4.0 gets 16 to 18 if I'm nice to it. I started getting 14 and replaced a O2 sensor and back to my normal range.
JeepFireman304 is offline
post #25 of 29 Old 02-06-2013, 03:35 PM
dsodko
Wj
I miss my '99 Grand. 6 cycl, Michelens, Syn oil & tuned up. I was getting 19mpg w/lead foot. Our '02 WJ get 15mpg w/4.7 V8.
IT IS A JEEP THING !
dsodko is offline
post #26 of 29 Old 02-06-2013, 05:56 PM
mycreativename
Hahaha I would kill for 14+ MPG.
99' WJ, 2.5" Rusty's, Bilstein 5100's, JKS TrackBar, Moog SuperTrailBoss
"With enough fabbing, time & $, it's certainly possible.
That being said, it's like boinkin' your sister...just because you can, doesn't mean you should." - Double E
mycreativename is offline
post #27 of 29 Old 02-06-2013, 07:35 PM
homerdog
I have an 02 4.0 I6 with a 2" BB 245/75-16. I did a Superchip economy tune and get 20+ highway @ 70mph. In city gets 17-18. I do coast to stops as much as possible.
2002 WJ Laredo, 4.0, 2"BB, Skyjacker Hydro Shocks, Hankook Dynapro ATM RF10 245/75R16, Powertrax No-Slip lockers Front&Rear, Superchip Flashpaq.
homerdog is offline
post #28 of 29 Old 02-06-2013, 07:50 PM
lazyWJ
2006 XK Commander
I can squeak 17mpg or so from my 02 4.7HO on the highway, but it's been cold here and I haven't run it in warm weather yet. On a related note, has anyone noted how the EVIC numbers compare to calculated numbers?
2004 Imola BMW ZHP
2006 Commander Limited Hemi QD2
"Bought, Not Built"
lazyWJ is offline
post #29 of 29 Old 02-06-2013, 09:14 PM
mycreativename
Its generally accepted that the EVIC is off more often than not in our WJ's. Mine is always quite optimistic since my fuel filter change.
Sent from my blimp fortress using my carrier pigeons.
