extremely low mpg? - JeepForum.com
post #1 of 29 Old 02-05-2013, 01:01 PM Thread Starter
braddf
extremely low mpg?
i have a stock wj with only 93000 on it and all i get is 14.6 mpg? i dont speed (will lose my jeep if i do) take off to what i would consider to be slow and i havent went offroad in a few weeks! ME AND MY WALLET NEED HELP!!!
braddf is offline
post #2 of 29 Old 02-05-2013, 01:07 PM
SKI_VT
thats better than what i get..
I dont know what your complaining about. its a jeep!
"You people make it sound like Claytons are made from gold and unicorn bones while everyone else uses PVC and spaghetti noodles."
"The Great Turtle Race! -> Iceland vs. Bushwhacker! -> Place your bets!"
SKI_VT is offline
post #3 of 29 Old 02-05-2013, 01:08 PM
lvngtheJEEPlife
Thats weird for stock.. Has all maintenance been keep up on? I.E. Spark plugs, oil, axle fluids, trans fluids, greasings, air filter, tire pressure? Pretty sure manufacturer stats only put the mpg at 14 and 16.. They are not fuel smart vehicles, But before i lifter mine i was getting about 16 city 18 highway.
2001 WJ Limited 4.7 Powertech, Quadradrive, 2" BDS lift.
"If you can't get there in a Jeep, You should reconsider going there."
lvngtheJEEPlife is offline
post #4 of 29 Old 02-05-2013, 01:13 PM
onionknight
Replace the fuel filter (it's less than $30). air filter. Spark plugs. use cruise control. maintain proper tire inflation.
I have found (along with a few other forum members) that accelerating quickly seems to be more efficient than dragging *** for a couple hundred yards while you get up to speed (something about the Jeep liking the midrange RPMs more). I have a V8, so I don't know if this applies to the 4.0.
Also, here are some tips for fueling up:
Gas up in the morning (gasoline condenses with the cold temperature at night, so 1 gallon in the morning is more than 1 gallon in the afternoon).
Fill up when you're at 1/2 tank (something to do with the floating roof in most gas tanks keeping the air out).
Fill up on the slowest setting (the faster the gas rushes in, the more turbulent it flows, and the more air it brings with it). More air means more gas evaporation.
onionknight is offline
post #5 of 29 Old 02-05-2013, 01:18 PM
ZCherokee4x4
1994 XJ Cherokee
Good tips did not know this
ZCherokee4x4 is offline
post #6 of 29 Old 02-05-2013, 01:39 PM
SKI_VT
Its because the dirt and crap settles and you don't want that in your fuel lines.
SKI_VT is offline
post #7 of 29 Old 02-05-2013, 02:08 PM
onionknight
Oh yeah, that was why.
post #8 of 29 Old 02-05-2013, 02:18 PM
WJlover
welcome to jeep
WJlover is offline
post #9 of 29 Old 02-05-2013, 02:21 PM
WJlover
has nothign to do with jeeps. same with every car.
ever wonder why you get the best gas mileage at highway speed?
higher gears get better gas mileage. so the less time you spend in lower gears, the better your mpg will be.
also, dont come to quick stops. try to use your brakes as little as possible when coming to a stop. try to coast to a stop. stopping all that momentum too fast uses gas.
WJlover is offline
post #10 of 29 Old 02-05-2013, 02:49 PM
ZeJokee
It's a jeep. You will be lucky to average much more than that, especially during the winter. My 99 4.7 when I bought it at 90,000 miles barely got over 15 average. Now if it was all highway driving it would get between 18 and 20. If you want something that gets more than 15, sell the jeep and get a car. Btw, I bought my WJ in Greenville, NC and drove all around Mt. Olive and Wallace. So same style of driving as you. I currently average 13mpg with it.
99 WJ Ltd, Blacked out, 4.7L, 242j Swap, 2'' BB, 245/75/16 Kuhmo Venture AT KL78, Flow Master Super 40, MagnaFlow high flow Cat, Akebono caliper upgrade, Addco rear swaybar, Westin brush guard, Moog Super Trail Boss, Rancho RS5000, Rola roof rack with dual kayak J hooks, PAC-AOEM-CHR, Sony Xplod 1200w amp, 2 Sony Xplod 12'' subs, 118,XXX miles (SOLD)
93 ZJ Ltd, Blacked out, 5.2L, Reman 46RH, Reman 242 Swap, 3.5'' IRO + 2" BB, 33x12.50r15 Mud Claw MTX radials, Bushwacker Flares, 216,XXX miles (Still parked in NC)
04 F-350 SD Crew Cab FX4 Lariat, 6.0 PSD SRW, Head studs, AFE Stage 2 SI Pro Guard 7 intake, Blue Spring mod, 150,XXX Miles
ZeJokee is offline
post #11 of 29 Old 02-05-2013, 02:59 PM
cykaaro
I use a program on my blackberry to track my gas mileage, and recently went to a site called www.fuelly.com which does the same. kind fo neat. Over the past year my avg is 13.5l/100km (my best has been 11.2) which translates to 17.4 mpg/ The interesting thing I've always noticed is my worst gas mileage occurs when I fill up if the tank is over half. If I fill up about the 3/4 mark, which I typically do, my mileage is better. Don't understand that one.
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #12 of 29 Old 02-05-2013, 03:01 PM
ZeJokee
I use fuel friend on the android and I notice the same thing. Mine has a tick to select if it is a full tank or not but if I fill up with only a half a tank it totally screws up the calculations. One time it said I got 55mpg, yeah right. It is how ever they calculate the mpg. It is better if you fill up at the same level so it has consistent data.
ZeJokee is offline
post #13 of 29 Old 02-05-2013, 03:06 PM
cykaaro
On the crackberry I use mileage meter. Works pretty good, but doesn't tell you really a reading if you only partially fill. I always do a fill up as its not worth stopping all the time to get gas to put in $20 here and $20 there. I know I could probably go 4 days to work and back on one tank but I fill up after 3 as I don't like running the tank that low. Ends up being typically around the 3/4 mark that way.
I just like that you can easily keep track of how your mileage is, and track it over time. My last fillup sucked, but then again it has been bad weather and I've been driving everywhere in 4WD which can have an effect.
cykaaro is offline
post #14 of 29 Old 02-05-2013, 03:26 PM
bigjohnsondohc
id be lucky to get 14mpg, I have an 04 4.0 and I average 10.9. Thats after new plugs, air filter, oil filter, oil and being babied.
bigjohnsondohc is offline
post #15 of 29 Old 02-05-2013, 03:44 PM
cykaaro
I'd have the cat and 02 sensors checked. Both can cause bad gas mileage if they are shot.
cykaaro is offline
