extended sway bar links or not? - JeepForum.com
post #1 of 12 Old 10-14-2013, 06:47 PM Thread Starter
ZJPunk98
Hi guys,
I have decided to go with Kolak's 3" old man emu lift for a long as my wj is a dd. Eventually I would like to complete my plan of a Clayton long arm kit.
Money is tight right now and I would like to know if I really need extended links at 3". I do plan to get with jks quick discos for the front and standard rear extended links, but they total and extra $200.
So do I need them right now or not?
I am already getting blilstein 5100 series shocks, 3" hd springs, jks adjustable tb, and new spring insulators.
thanks for the insight.
Erik
98 ZJ 5.2L JGC Limited Sold
02 4.7L HO JGC Overland
ZJPunk98 is offline
post #2 of 12 Old 10-14-2013, 07:11 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
You should be fine in the rear, but definitely extend the fronts.
~James
ezflip is offline
post #3 of 12 Old 10-14-2013, 07:29 PM
AIRBORNE
I did the same exact setup. I installed the rear links tonight. Going to do the fronts tomorrow.
2000 Grand Cherokee Limited/ Quadra Drive / 4.0L/ OME HD springs, Bilsteins, JKS trackbar, 255/75/17 BFG M/T with JK Moabs
2005 Silverado 2500 HD Duramax
United States Army (2004-present)
AIRBORNE is offline
post #4 of 12 Old 10-14-2013, 07:33 PM Thread Starter
ZJPunk98
ok... well it looks like I will do the links now.
Erik
ZJPunk98 is offline
post #5 of 12 Old 10-15-2013, 09:39 AM
Merc1973
Get both front and rear. I noticed an improvement when i did. I got the Zone 3" from amazon for cheap.
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
1970 Kaiser-Jeep M35A2 W/OW 6x6 Multifuel D-Turbo.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
post #6 of 12 Old 10-16-2013, 02:28 AM
tuglife
I have the OME HD springs and Bilstein 5125 shocks no extended sway bars no adj TB. Had it that way for a couple years now. No probs. btw I only netted 2.25-2.5 all around on my 04 Overland w/ HO V8. If you get a full 3" then good for you but that's not what I experienced. Didn't swap the coil insulators as I wish I had but the jeep had 60k miles and they looked in great shape. If you get a full 3" I'd recommend it. I didn't and am doing fine.
I do get a front end thunk when I hit a hard bump at speed. It is on the compression though not the expansion so still no idea what that is.
,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,2004 WJ Overland ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
4.7 HO V8, K&N FIPK, Old Man Emu HD Springs, Bilstien 5100, 31" 255/70/17 Bridgestone Dueler A/T Revo 2, Black JK Moabs, Overland Rock Sliders, Tow Hooks, Westin Brush Guard, GTP Hood Vents, Mopar iPod Integration Kit
tuglife is offline
post #7 of 12 Old 10-16-2013, 07:10 AM
jpat30
I have the same OME HD setup and I did not opt for extended links and have had no problems.
-Carpe Diem Phil 1:20
jpat30 is offline
post #8 of 12 Old 10-16-2013, 07:24 AM
ChrisHager
Administrator
ChrisHager's Avatar
I originally went with extended in both the front and rear. I then changed things up a bit and put the stock back in the front. Here is my post from my build thread on the subject:
Originally Posted by ChrisHager View Post
Small update - Recently I've felt the WJ had a little sway to it when cornering, almost as if it was tucking in to the turn. This was most noticeable at higher speeds when following a bend in the road. I had originally installed the Zone sway bar end links when I installed the OME HD lift. After a talking to billzcat1 a while back and finding that ideally, you want the sway bar to sit at 0, I decided I would switch back to the OEM end links.
Here's the angle I had with the Zone end links:
And here's one with the OEM links:
I realize the 'after' picture means nothing without a level on it. I will try to swap that picture out with a better one when I can get back into my garage (borrowed floor space)! Either way, perhaps I'm working with the placebo affect but I feel like it follows curves at higher speeds a bit better.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline
post #9 of 12 Old 10-16-2013, 09:19 AM
texlurch
Stock and recommended swaybar angle is +/- 30 degrees.. your first pic looks closer to 45, and the second pic looks like around 10-15?
See notes in this thread: http://www.jeepforum.com/forum/f310/...ments-1299222/
Someone can take a pic of a stock Dub front bar just to verify...
Just another old fart in a Jeep... watchout younguns!!!
RC LA, IRO 6 in springs, OTK, Bilsteins, Aussie, Eaton, RCV's, 242-SYE, hidden winch, JCR Stage 3, skidded and trussed & sleeved
Colorado Jeep Club Member #383
texlurch is offline
post #10 of 12 Old 10-16-2013, 02:32 PM
its-me-B
i have extenders on the rear and left the front alone. you can go pick up a peice of 2x2 square tubing and make your own for cheap...
Do the world a favor, hurt a honda...
Iro 3" lift with pro comp 9000es shocks, adjustable trackbar, led rock lights, all interior lights converted to leds, two 10" kicker comp with Kenwood 600 watt amp
Zombie Outbreak Response Unit #396
its-me-B is offline
post #11 of 12 Old 10-16-2013, 04:50 PM
theonlybull
i have no rear sway, and run stock front links, with a 4" RC lift, drives fine :-)
theonlybull is offline
post #12 of 12 Old 10-16-2013, 05:00 PM Thread Starter
ZJPunk98
interesting insight guys, thanks.
Erik
ZJPunk98 is offline
