-   WJ Grand Cherokee Forum (http://www.jeepforum.com/forum/f310/)
-   -   extended sway bar links or not? (http://www.jeepforum.com/forum/f310/extended-sway-bar-links-not-1685009/)
ZJPunk98 10-14-2013 06:47 PM
Hi guys,
I have decided to go with Kolak's 3" old man emu lift for a long as my wj is a dd. Eventually I would like to complete my plan of a Clayton long arm kit.
Money is tight right now and I would like to know if I really need extended links at 3". I do plan to get with jks quick discos for the front and standard rear extended links, but they total and extra $200.
So do I need them right now or not?
I am already getting blilstein 5100 series shocks, 3" hd springs, jks adjustable tb, and new spring insulators.
thanks for the insight.
ezflip 10-14-2013 07:11 PM
You should be fine in the rear, but definitely extend the fronts.
AIRBORNE 10-14-2013 07:29 PM
I did the same exact setup. I installed the rear links tonight. Going to do the fronts tomorrow.
ZJPunk98 10-14-2013 07:33 PM
ok... well it looks like I will do the links now.
Merc1973 10-15-2013 09:39 AM
Get both front and rear. I noticed an improvement when i did. I got the Zone 3" from amazon for cheap.
tuglife 10-16-2013 02:28 AM
I have the OME HD springs and Bilstein 5125 shocks no extended sway bars no adj TB. Had it that way for a couple years now. No probs. btw I only netted 2.25-2.5 all around on my 04 Overland w/ HO V8. If you get a full 3" then good for you but that's not what I experienced. Didn't swap the coil insulators as I wish I had but the jeep had 60k miles and they looked in great shape. If you get a full 3" I'd recommend it. I didn't and am doing fine.
I do get a front end thunk when I hit a hard bump at speed. It is on the compression though not the expansion so still no idea what that is.
jpat30 10-16-2013 07:10 AM
I have the same OME HD setup and I did not opt for extended links and have had no problems.
ChrisHager 10-16-2013 07:24 AM
2 Attachment(s)
I originally went with extended in both the front and rear. I then changed things up a bit and put the stock back in the front. Here is my post from my build thread on the subject:
Originally Posted by ChrisHager (Post 13977704)
Small update - Recently I've felt the WJ had a little sway to it when cornering, almost as if it was tucking in to the turn. This was most noticeable at higher speeds when following a bend in the road. I had originally installed the Zone sway bar end links when I installed the OME HD lift. After a talking to billzcat1 a while back and finding that ideally, you want the sway bar to sit at 0, I decided I would switch back to the OEM end links.
Here's the angle I had with the Zone end links:
http://i1103.photobucket.com/albums/...s/IMAG0021.jpg
And here's one with the OEM links:
http://i1103.photobucket.com/albums/...s/IMAG0526.jpg
I realize the 'after' picture means nothing without a level on it. I will try to swap that picture out with a better one when I can get back into my garage (borrowed floor space)! Either way, perhaps I'm working with the placebo affect but I feel like it follows curves at higher speeds a bit better.
texlurch 10-16-2013 09:19 AM
Stock and recommended swaybar angle is +/- 30 degrees.. your first pic looks closer to 45, and the second pic looks like around 10-15?
See notes in this thread: http://www.jeepforum.com/forum/f310/...ments-1299222/
Someone can take a pic of a stock Dub front bar just to verify...
its-me-B 10-16-2013 02:32 PM
i have extenders on the rear and left the front alone. you can go pick up a peice of 2x2 square tubing and make your own for cheap...
theonlybull 10-16-2013 04:50 PM
i have no rear sway, and run stock front links, with a 4" RC lift, drives fine :-)
ZJPunk98 10-16-2013 05:00 PM
interesting insight guys, thanks.
The time now is 10:18 PM.
