Exhaust with Clayton Back Half - JeepForum.com
post #1 of 7 Old 05-30-2012, 07:38 AM Thread Starter
Cebby
I had heard that I would need to do some exhaust mods to get the Clayton Rear Long Arms to fit, but figured I could at least weld the brackets on. Well, I was wrong - I have a Borla cat-back and discovered that the brackets interfere with the Borla muffler. Since I have to replace some parts anyway, I thought I should keep the Borla catback intact and build something like I had seen others build. Specifically, a shortened assembly of the cat & muffler with a turn-down before the rear axle.
So I went to measure up what was under there and found something odd. The pipe going into my main cat is 2.5", but the outlet is 2.25". This is the factory cat. I've heard that some back pressure is desirable for low end torque, so wondering if that was the reason for the step down. My question - if I go all 2.5", am I going to lose power? Only have the 4.0 - stock 3.55 gears with 32's. It's just acceptable now - don't want to make it worse.
The thought was to replace the OEM cat with a Magnaflow 2.5" in/out and a 2.5" in/out muffler.
2000 WJ Laredo 4.0 4x4 Taupe Frost - Stroker | Clayton LA w/3" Lift | 33's on JK 17's | Axles next
Cebby is offline
post #2 of 7 Old 05-30-2012, 10:02 AM
adavis39
your going to replace your cat with a muffler? IMO i'd cut your exhaust sytem off after the OEM cat and run a small muffler (ull HAVE to to clear the clayton arms) like a flow master hushpower then a turn down. several people run that set up with no issues. it will clear fine and should not hinder performance. If your state laws require your exhaust to clear the rear of the vehicle then you will most likely be looking at a custom piep set up to allow the arms to fully flex. ive got a hushpower that i never installed that i'd sell ya but its a 2.5 in/out. just my two cents
2002 WJ Limited 4.7: 6" Clayton REALLY long arms....yep, they are longer than yours SOLD : (
1998 Platinum 5.9 DD
2007 WK Overland 5.7 wifes DD
TNJEEPS.COM
BUILD:
"In a world that he did not create, but he will go through it as if it is his own creation. Half man, half beast, whatever it is it is weird, it is ticked off and it calls itself Slash"
adavis39 is offline
post #3 of 7 Old 05-30-2012, 10:08 AM
skain8
skain8's Avatar
I'm also in PA and have a full pipe rear-exit set-up with my Clayton rear 4 link. I sourced a small rectangle offet case, high-flow (but quiet) muffler and its been great. It is high clearance and does not interefere with the rear suspension cycled. A local exhaust shop should be more than competent to handle this task. I will take a few pics of my set-up for you if you'd like.
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is offline
post #4 of 7 Old 05-30-2012, 10:14 AM Thread Starter
Cebby
Would love some pics! Thanks.
Cebby is offline
post #5 of 7 Old 05-30-2012, 10:22 AM Thread Starter
Cebby
I wasn't going to replace the cat with a muffler, but a more flat shaped cat from Magnaflow (compared to the almost round OEM one). The idea is to move it toward the motor on the front side of my Clayton front crossmember, then have a decent size muffler with down turn right after the front cross member. (don't want to be louder than the Borla cat-back I have) I'll eventually run a tailpipe out the back, but wanted to do something so I can get to/from my buddies shop (I'm welding the brackets on, but he has a lift/garage so it will be easier to get the arms on/adjusted instead of me working in my gravel driveway LOL)
Cebby is offline
post #6 of 7 Old 05-30-2012, 10:39 AM
adavis39
ok, i read that wrong..seemed like thats what you were saying...if you just need to do something temporarily to get to your friends shop then you can just cut it off after the cat. that will give you plenty of room to weld on the brackets and get everything assembled. then you can mess around with your exhaust set up
TNJEEPS.COM
BUILD:
adavis39 is offline
post #7 of 7 Old 05-30-2012, 10:47 AM
adavis39
also, here are some pics of theksmiths set up. i always liked it just havent had time to get around to doing it for mine. but it seems like what you are going for
http://www.jeepforum.com/forum/f197/...60/index4.html
TNJEEPS.COM
BUILD:
adavis39 is offline
clayton back half , clayton long arms , exhaust mods , magnaflow , pipe size
V8 WJ cat-back Exhaust w/Side-Exit JeffreySCooper WJ Grand Cherokee Forum 39 05-29-2012 06:59 PM
Clayton Long Arms and Exhaust tsconver WJ Grand Cherokee Forum 23 05-24-2012 07:20 AM
Anyone running Summit Racing SUM-640002 cat back exhaust? BSweet WJ Grand Cherokee Forum 4 12-08-2011 11:16 PM
looking for pictures of Clayton LA & Exhaust rerouting embee WJ Grand Cherokee Forum 3 02-26-2011 05:25 AM
WJ Clayton Exhaust Configurations JayIV WJ Grand Cherokee Forum 6 08-22-2008 04:26 PM
