Exhaust blowing white smoke.. Is this normal? - JeepForum.com
post #1 of 16 Old 07-10-2012, 10:29 AM Thread Starter
qbny94
Just noticed when i start my jeep i have the 4.7l that my exhaust is blowing out whitish color smoke is that normal?
qbny94 is offline
post #2 of 16 Old 07-10-2012, 10:42 AM
Overland_03
2003 WJ
If its just on start up, its probably condensation coming out the exhaust. If its all the time then its probably a blown head gasket.
Overland_03 is offline
post #3 of 16 Old 07-10-2012, 10:45 AM Thread Starter
qbny94
Well there was water dripping from my exhaust but i let my engine run for about 5 mins and white smoke was still coming out
qbny94 is offline
post #4 of 16 Old 07-10-2012, 10:49 AM
Jacko84
Is it smoke or vapor? Any odor?
02 WJ Limited | 4.7L HO | quadra-drive | 3" KOLAK lift: Bilstein 5100s shocks, OME HD coils | Moog steering stabilizer | JKS adjustable track bar | 245/70R17 General Grabbers | 17" JK MOABS
Jacko84 is offline
post #5 of 16 Old 07-10-2012, 11:51 AM Thread Starter
qbny94
I dont think there was odor just a white smoke kinda
qbny94 is offline
post #6 of 16 Old 07-10-2012, 11:58 AM
Jacko84
White smoke could mean that you are burning oil or coolant for some reason. Coolant would be a bad head gasket
Jacko84 is offline
post #7 of 16 Old 07-10-2012, 02:25 PM
Double E
Double E's Avatar
With suspicious smoke, there's also the need to look at the overflow of the coolant resevoir & assess if it has lost fluid. Mark the level when cold & on level ground. Check again in a week or so, park in same spot, draw a new line.
There's also a test to see if there are disolved exhaust gasses in the coolant. Most garages use them these days. http://www.ehow.com/video_12213890_c...ntifreeze.html
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #8 of 16 Old 07-10-2012, 03:08 PM
hamilton5
I don't see cars spewing white smoke all the time but g, i have no common sense...
hamilton5 is offline
post #9 of 16 Old 07-10-2012, 07:58 PM
Cowboyup94
^BAHAHAHA!!! as said check your fluid recovery bottle and assess appropriately
JEEP
Just Emptying Every Pocket
Cowboyup94 is offline
post #10 of 16 Old 07-11-2012, 12:20 AM
DevinB
Typically, blue smoke is oil and white smoke is coolant. Like Double E said above, take it to a shop and they can tell right away with that little doohickey that will sniff for hydro carbons in your coolant.
DevinB is offline
post #11 of 16 Old 09-13-2013, 05:11 PM
djbchill
Having the same problem. It just started. White smoke, no smell and it looks like something was spraying out because there are little liquid spots on the back of the Jeep. The engine was bucking a little however it subsides when the air conditioner is cut off. At slower speeds no smoke comes out. What could be the problem?
djbchill is offline
post #12 of 16 Old 09-15-2013, 01:27 PM
MurphysLaw_WJ
Wj same issue
my 4.7 is doing the same things...intermitten...no change in coolant level, no leaks, no loss in power...
i have a tiny tiny oil leak (no traces on the ground just slow drop in oil levels over weeks).... but the smoke is white....
i need a new cat.....but doubt that has anything to do with it...
passed a compression test so im really confused.... bad valves?
MurphysLaw_WJ is offline
post #13 of 16 Old 09-15-2013, 01:31 PM
gtg413i
2003 WJ
White smoke is pretty common for these 4.7 engines imho.
Brian's Black Betty Build:
gtg413i is offline
post #14 of 16 Old 09-19-2013, 10:31 AM
kfxnando
agree
however need to ask
is it white smoke or just a lot of vapour, and water coming out the exhaust??
if its gasket then there will also be a drop in water lever for a start
my one has been doint that for a long time, its just condensation
specially if it has no smell
a unrestricted exhasust will make it even worst, for those who know what I mean!!
http://s538.photobucket.com/user/kfxnando/library/?sort=3&page=1
kfxnando is offline
post #15 of 16 Old 10-12-2014, 12:11 AM
dogsgirl6
Tj white smoke out of exhaustt
I have a 98 TJ that is blowing white smoke with fumes and makes an awful squealing under the hood. I have replaced the oil pan gasket and it is not hesitating any more but still blowing smoke. Any ideas?
dogsgirl6 is offline
