Engine squeals above 3000 rpm - JeepForum.com
post #1 of 13 Old 07-14-2013, 09:22 PM Thread Starter
rloew275
So I have a 2001 with an I6 and when I try to accelerate it hits 3000 rpm it starts to squeal and i can't get any more power out of it, the squeal is very loud and beyond noticeable, comes abruptly and will go away once it shifts. It doesn't matter what gear I'm in... It's almost religiously At 3000 on the dot. any clue to what's causing this??
rloew275 is offline
post #2 of 13 Old 07-14-2013, 09:59 PM
WJChris
WJChris's Avatar
loose serpentine belt?
It goes away when it shifts, because it drops below the 3k RPM!
WJChris is offline
post #3 of 13 Old 07-16-2013, 12:07 PM Thread Starter
rloew275
I know why it goes away when it shifts lol.just trying to be as detailed as possible. Although I checked the belt, it's tight and all the pulleys are solid, nothing seems loose!
rloew275 is offline
post #4 of 13 Old 07-16-2013, 06:46 PM
WJChris
WJChris's Avatar
Im sure it "feels" tight, but have you actually followed the proper way to tighten it/check for looseness? How is the condition of the belt?
WJChris is offline
post #5 of 13 Old 07-16-2013, 07:13 PM
pinky2252s
With modern belts, you can't really tell how good they are working by just looking at them, they make look perfect but they might not be holding tension.
I would go buy a new belt, and when the old one is off spin all the pulleys to make sure they are free spinning. Its most likely just your belt that is slipping at high RPM's.
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
pinky2252s is offline
post #6 of 13 Old 07-20-2013, 07:17 AM Thread Starter
rloew275
Before I buy a new belt.. How do you tighten one?
rloew275 is offline
post #7 of 13 Old 07-20-2013, 07:24 AM
narnwv
narnwv's Avatar
You don't. Its an automatic tensioner.
Typing on phones sucks.
~Aaron
narnwv is offline
post #8 of 13 Old 07-22-2013, 06:08 AM Thread Starter
rloew275
Alright, I'll get a new belt and see if that helps!
rloew275 is offline
post #9 of 13 Old 07-22-2013, 08:39 AM
SteelBlue_WJ
SteelBlue_WJ's Avatar
you will need a new pulley too. its cheap and easy to install
Bobby
2001 Steel Blue WJ Laredo SA 4x4, 3.5" lift, Apperance Package with factory Laredo Steel Blue cladding/leather
Conferr Roof Basket with custom Randy Ellis Design light cage, WAAG grille guard and Hella lots of 500 lights
2004 Wrangler Sport, 2.5" and 31's, nothing special
"For all sad words of tongue and pen, the saddest are these, 'It might have been.' "
John Greenleaf Whittier
SteelBlue_WJ is offline
post #10 of 13 Old 08-04-2013, 07:09 PM Thread Starter
rloew275
Driving today and I noticed something else... When the engine hits around 3000 rpm, the fan will quit increasing in speed and that's when the squealing begins... The engine will continue to speed up and accelerate but the fan gets to its "max speed" and then stays at that speed.
rloew275 is offline
post #11 of 13 Old 08-04-2013, 07:10 PM Thread Starter
rloew275
I can tell when the fan is accelerating with the engine because it's loud as f***
rloew275 is offline
post #12 of 13 Old 08-04-2013, 11:55 PM
pinky2252s
Did you ever replace the belt and the pulley?
Is it broken?
post #13 of 13 Old 08-05-2013, 05:54 AM Thread Starter
rloew275
I haven't had time yet, I've been working on the road the past week and a half.
rloew275 is offline
