engine running hot - JeepForum.com
post #1 of 2 Old 04-10-2012, 10:22 AM Thread Starter
4x4Jeep
engine running hot
this past weekend i was out mudding, and got tons of mud on my radiator and the trans. cooler. started overheating but i got most of the mud off with water. when i got home i used a pressure washer from a car wash to get the left over mud out, but it still runs hot, although not as much. it's my dd and i have the heat on high to get to work and back. the temp. gauge runs at the 3/4 mark, 210 is the normal. it hasn't gone in the red though.
what are some things i can do or check do get it running normal again? do i need to flush the radiator? should i remove the radiator to make sure no mud is left in it? is that hard to do? i have the 4.0 engine. thanks.
Build -
SOLD
4x4Jeep is offline
post #2 of 2 Old 04-10-2012, 10:24 AM
rjrorrer
chances are the radiator fins could be clogged with mud. when I did mine i took the radiator out and used a small screw driver to "punch" the fins out. It would also be a good idea to replace your thermostat if you have not done so.
1969 Nova,350, bored 40 over,voodoo cam heads ported and polished ,700r4 with shift kit and 2800 stall,8.5 bolt, 3.73 gear
rjrorrer is offline
mud , overheating , radiator , running hot
Very fast running 4 litre engine markpin WJ Grand Cherokee Forum 7 01-23-2012 06:25 AM
Necessary to bleed brakes when engine running? Why are my brakes still soft? ct-snoman WJ Grand Cherokee Forum 6 11-28-2011 11:52 PM
E-fan turns on by key w/o engine running ?? wsar10 WJ Grand Cherokee Forum 4 09-19-2011 09:01 PM
Help! Check engine light on, crazy engine noises. vtavarez WJ Grand Cherokee Forum 3 08-25-2011 07:15 AM
engine died on 2002 grand cherokee, looking for a new/used engine dralbundy7 WJ Grand Cherokee Forum 3 07-16-2010 12:15 AM
