Engine rotates but will not start. - JeepForum.com
post #1 of 31 Old 10-10-2013, 01:00 AM Thread Starter
pitsy
Here's what I know: Battery is good. Fuel pump works, fuel level sender works. Fuel pump relay and ASD relay are good. All fuses in power distribution center are good; all fuses under the dash are good. There is fuel at the rail, but I have not gauged the pressure yet.
I disconnected the ignition coil rail connector and checked for voltage between the DG/OR wire and ground with the key to 'ON'... Zero Volts. Should show system voltage, right?
Also, the instrument cluster illuminates, but doesn't read anything on any of the gauges.
What do I check next? I feel like I'm missing something obvious.
This Jeep was driven up north and has 131k miles on it. Wiring in the engine looks clean, but everything underneath this beast is sketchy.
This is my first Jeep, given to me by a family member. It was running a few months ago but it wouldn't start one day so there it sits. Help me get it running so I can drive it!
pitsy is offline
post #2 of 31 Old 10-10-2013, 07:00 AM
snoWJ
You clean the battery terminal heads? Similar thing happened to me and it was due to corrosion on the neg battery terminal. Cleaned it up and it started back up
snoWJ is offline
post #3 of 31 Old 10-10-2013, 07:22 AM
WJ02FNG
Also jump start the car using another vehicle. Many times the battery "tests" good, but doesn't have the juice to start the Jeep. If it starts up, it's a bad battery.
2002 Jeep Grand Cherokee 4.0L, 4x4, Selec-Trac TC, Auto Transmission
K&N drop-in air filter, B&M Supercooler Transmission Cooler, Rusty's Off Road Front Tow Hooks, Mopar Hitch. Iron Rock Off Road 3 inch lift.
WJ02FNG is offline
post #4 of 31 Old 10-10-2013, 07:28 AM
Chris00WJ
You say the engine rotates so I'm going to assume that its turning over strongly.
No idea about the voltage at the connection you are asking about, but start with the absolute basics.
For an engine to run you need fuel, spark and compression. If it just stopped running one day without a major incident then compression is likely fine.
Give yourself the best chance you can and get fresh fuel in there. Turn it over for a bit trying to start it and then pull a spark plug. Is it wet with fuel?
If not, you've got a fuel issue.
If so, then its a pretty safe bet its a spark issue.
Does it stumble and try to start at all? Or just turns over and over and over?
2000 Jeep WJ Laredo - 4.7L, 3" IRO Lift kit, JKS adjustable track bar, 242J TC swap, BFG KM2 32's on JK takeoffs, Leather interior swap, Custom CAI, front hitch receiver, homelink EVIC swap etc
Chris00WJ is offline
post #5 of 31 Old 10-10-2013, 10:02 AM Thread Starter
pitsy
OK, more info. The initial problem was a burnt fuel pump, which I've replaced with a new unit. Before there was no fuel pressure at the rail and the pump wouldn't run. After replacing it, the pump runs and there is pressure.
The engine turns over strong, battery terminals are clean. Five gallons of fresh fuel in a clean tank.
The Haynes manual says I should see battery voltage at the wire I mentioned, as it supplies power to the coil rail.
I have until next Tuesday to come up with something to test or replace. Been racking my brains and trying to read the schematic. I SUCK at reading schematics.
pitsy is offline
post #6 of 31 Old 10-10-2013, 10:15 AM
WJ02FNG
Have you checked your grounds? Specifically check the ground from the valve cover to the firewall.
WJ02FNG is offline
post #7 of 31 Old 10-10-2013, 12:27 PM Thread Starter
pitsy
I have not checked the grounds yet, but I will. However, shouldn't there still be voltage present at the coil rail? I tried with the negative multimeter probe on the block, a body ground, and the battery negative terminal, and the positive lead on the feed wire in the connector.. Zero voltage.
pitsy is offline
post #8 of 31 Old 10-10-2013, 12:31 PM
WJ02FNG
I suppose. Just suggesting the simple things first. Please post follow up!
WJ02FNG is offline
post #9 of 31 Old 10-10-2013, 12:48 PM Thread Starter
pitsy
No, that's helpful! I feel like it's something obvious, so checking grounds is good advice.
Any idea why the gauges aren't reading? They should at least show battery voltage and fuel level with the key on....
pitsy is offline
post #10 of 31 Old 10-10-2013, 12:52 PM
WJ02FNG
That's why I'm suggesting grounds-others have reported the same symptoms. Also, who checked the battery? Just because the voltage is good doesn't mean it has enough power to satify the PCM and start the jeep. Try to jump it with another vehicle. It has worked for others.
WJ02FNG is offline
post #11 of 31 Old 10-12-2013, 08:13 AM
WJ02FNG
WJ02FNG is offline
post #12 of 31 Old 10-12-2013, 01:08 PM
rm2001wj
rm2001wj's Avatar
My reply to your other thread (http://www.jeepforum.com/forum/f310/.../#post16779745) applies here also.
rm2001wj is offline
post #13 of 31 Old 10-12-2013, 09:55 PM Thread Starter
pitsy
There's no follow-up yet. Sunday is family day and I prob don't have the gas to get out there Tuesday. In the meantime I'm in research mode, learning about the systems involved and formulating hypotheses. There's no real pressure to get it running, other than my GF's dad wanting it off his driveway, and the fact that I enjoy a challenge. I've got an hour free tonight; I'm gonna stare at the wiring diagram and see if something in my brain clicks.
pitsy is offline
post #14 of 31 Old 10-13-2013, 09:42 AM
Double E
Double E's Avatar
Go back to the basics.... get a can of starting fluid aerosol (2 is best) and have someone spray the intake (Airbox plumbing off) while you turn it over. That will tell you where the problem is and is not. If it runs, the problem is fuel delivery or bad fuel. If not, the problem is likely after fuel delivery such as electircal, PCM or ignition-related.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #15 of 31 Old 10-13-2013, 12:58 PM
86cj74.2L
86cj74.2L's Avatar
If you do the key thing to check for codes and get no response there is something wring with the PCM or its communication network.
When you say the instrument cluster gauges are dead do you have anything showing in the odometer display. That cluster is a computer in and of itself. It receives all its info from the network (PCI Buss) that it uses to communicate with all the modules.
86cj74.2L is offline
