engine diagnostic codes - JeepForum.com
post #1 of 7 Old 09-18-2013, 12:26 PM Thread Starter
bambam634
I just bought the jeep 1 month ago and no engine light was on had it for maybe a week and im getting codes
p0132
p0141
p0161
all seem to be with the o2 sensors however the owner claims he replaced them 3 months ago I can see 2 and they both seem to be clean and shiny like new should there be more then 2 o2 sensors
bambam634 is offline
post #2 of 7 Old 09-18-2013, 12:38 PM
ChrisHager
Administrator
ChrisHager's Avatar
It depends. Federal Emissions use 2 while California Emissions use 4. It could be that the PO used 'cheap' sensors. WJs are very picky with sensors. You're going to want Mopar O2 sensors. Take a look through this thread then contact Kolak here on JeepForum.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #3 of 7 Old 09-18-2013, 02:16 PM
MeanGreenZJ
The fact the owner claims he replaced them 3 months ago could be the problem itself. It can be as simple as using Bosch O2 sensors.
MeanGreenZJ is offline
post #4 of 7 Old 09-18-2013, 03:47 PM
nickblack
Are you suggesting he use Bosch sensors or did you mean the explanation of his potential failure is because the PO used Bosch O2 sensors? You're statement was a little ambiguous. Any who, use Mopar O2 sensors only.
nickblack is offline
post #5 of 7 Old 09-18-2013, 04:26 PM
MeanGreenZJ
Avoid at all cost. Bosch O2 sensors don't work well on Chrysler products.
post #6 of 7 Old 09-18-2013, 04:42 PM
nickblack
Agreed!
post #7 of 7 Old 09-19-2013, 10:01 AM Thread Starter
bambam634
sounds good i will save up some money and purchase Mopar thanks
