engine cuts out while driving, - JeepForum.com
post #1 of 24 Old 07-15-2011, 01:37 PM Thread Starter
NELLY246
help please, ive only had this cherokee 2months , at first it didnt cut out, then it got worse , this week it has cut out on me and wont start, unless u leave it for a few hours, up till now it will start , but as soon as it gets upto temp it happens again, and its pot luck if it starts.when it cuts out its like somone has switched the engine off, all the das board lights go out and of course loss of powered steering and brakes, not good with caravan on back. dont think its anything to do,with the fuel as it happens on petrol or gas, just checked the rail and there is petrol there, so it seems to be getting through. ANYBODY HELP PLEASE.
forgot to mention its 4ltr 1999 model, newer shape
NELLY246 is offline
post #2 of 24 Old 07-15-2011, 02:23 PM
wsar10
2003 WJ
wrong forum, if its an XJ.....
but none the less, possibly a crank position sensor ??
QUOTE=billzcat1;wsar10 is right on point on this oil thread - as usual. Anyone reading this would be well-served taking his advice.
-03 WJ laredo 4.0 120k a few minor mods
-93 XJ 5spd, 3" zone lift
wsar10 is offline
post #3 of 24 Old 07-15-2011, 02:27 PM
WJguyinKC
^Agreed. But do this process to check for what code it is throwing (not sure, but I think this works for XJ's as well):
Turn the ignition key until the digital odometer displays, repeat three times in succession and then back to "On" (On/Off, On/Off, On/Off, On). At the fourth "On" the odometer will be replaced with codes. If no codes are present then "Done" will appear.
Once you get the code, post it here
WJguyinKC is offline
post #4 of 24 Old 07-15-2011, 04:16 PM Thread Starter
NELLY246
thanks for getting back to me, first of all i think it is a wj, reg it wrong on site , will change,
done what u said , the following codes came up,
P0320
P0171
P0138
P0131
DONE.
i hpoe this means something to u and its not too expensive, but of course it always is
NELLY246 is offline
post #5 of 24 Old 07-15-2011, 04:37 PM
WJguyinKC
Ok. P0320 is the crankshaft positioning sensor. That is what's causing your problem. The sensor goes in at the top of the bell housing of the tranny. Nearly impossible to get to. But if you support the transmission crossmember with a jack, undo the bolts, and then lower the tranny a couple of inches, it becomes an easy job.
Google your other codes along with terms like Grand Cherokee or 'WJ' to find out what they may be.
A great site for us WJ owners is www.wjjeeps.com
Lots of great info.
post #6 of 24 Old 07-15-2011, 04:50 PM Thread Starter
NELLY246
im no mechanic, this sounds too complicated for me mortal, being as i dont know what the tranny is etc, looks like being a garage job , but thanks for the info
NELLY246 is offline
post #7 of 24 Old 07-15-2011, 05:19 PM
wildeman_13
Lots of great info.
I just got the news from the repair shop on mine and this was the issue. I had the same trouble as you along with it only letting me start it in neutral for the past few weeks. Gonna cost me $320 parts and labor.
wildeman_13 is offline
post #8 of 24 Old 07-16-2011, 05:55 AM Thread Starter
NELLY246
Thats not bad , but i live in great britain, so i bet it will be double that, too expensive to ship it to the states,may consider doing it my self, we will see
NELLY246 is offline
post #9 of 24 Old 07-16-2011, 06:58 AM
4Tom
You maybe on right forum
If yours looks like the 1999 to 2004 models. Then it's a wj. Sometimes in England they call them wg.
WJ 2001 3.1TD
Tom
4Tom is offline
post #10 of 24 Old 07-16-2011, 07:02 AM
4Tom
When pricing jeep parts in uk do a quick check with US for comparison
I often find it cheaper to have shipped from states.
WJ 2001 3.1TD
Tom
4Tom is offline
post #11 of 24 Old 07-16-2011, 11:33 AM
wsar10
2003 WJ
are you freaking kidding me, You could have drove to my mechanic here in PA and had him do the job and drove all the way back to Cali and probably saved 100 bucks
I just went through this last month, 50 bucks for the part 40 bucks for an hours labor to put it on.
Jeep not stalling at red lights......priceless !
wsar10 is offline
post #12 of 24 Old 07-16-2011, 11:50 AM Thread Starter
NELLY246
Just seen a video on u tube, looks easy, going to have a go this week.
NELLY246 is offline
post #13 of 24 Old 07-16-2011, 08:27 PM
WJguyinKC
Ya, I think I found that video when I did mine, but it's for the generation of Grand Cherokees before ours (ZJ). The apace it shows you can slide your arm through doesn't work on ours.
If u get into it and have troubles let me know. I can take pics of what u need to and walk u thru it.
post #14 of 24 Old 07-17-2011, 08:59 AM Thread Starter
NELLY246
Thanks for that, ive got to wait for the part , so it will be later on in the week, the u tube vid i saw, they only removed a bracket which gave access to the fixing bolt to cps, will let u now how i get on thanks
NELLY246 is offline
post #15 of 24 Old 07-18-2011, 08:39 AM Thread Starter
NELLY246
i think you are wright about the u tube vid, its on a 1995 model, if you could point me in the wright direction on how to find and replace the cps on our model it would be appreciated, other wise its back to the first idea , take it to garage
NELLY246 is offline
1999 GC overheating - at all times idle/city driving/highway driving... dublove WJ Grand Cherokee Forum 8 07-23-2011 01:08 PM
2001 4.0 cuts off gshep WJ Grand Cherokee Forum 1 07-16-2011 02:29 PM
Jeep engine shuts off while driving/moving and comes back on. weber0411 WJ Grand Cherokee Forum 2 05-27-2011 09:24 AM
Does Beach Driving = Higher Engine Temps? VA-WJ WJ Grand Cherokee Forum 22 05-23-2011 05:23 PM
Check engine light driving me CRAZY!!! footbal9584 WJ Grand Cherokee Forum 14 04-26-2010 06:29 AM
