Engine compartment light upgrade. Write-up. - JeepForum.com
post #1 of 35 Old 03-26-2014, 12:50 PM Thread Starter
fayceoff
fayceoff's Avatar
Wj Engine compartment light upgrade. Write-up.
OK, so my 1999 WJ had one bulb under the hood which was giving me next to nothing for light output. I tried upgrading to an LED bulb, but it was still not much light, and it was nearly unidirectional. Then the other day I was at KMart and I saw these 12" Pilot LED strips on the clearance rack for nine bucks apiece and picked up two packages.
I took them home and pulled the light/switch assembly from the engine compartment. (Just squeeze the connector to disconnect it, then carefully pry the black housing loose.). Feed a jewelers screwdriver into each corner to release the clear plastic cover. In case you don't know, there's a ball switch in the assembly - kind of like a float switch - it has a ball in it that rolls back to make contact and turn on the light when you open the hood. So I took two short (about 4") sections of 16 gauge wire and soldered them to the two ends of the connector like this...
The strips are flexible and peel/stick, so I picked out the spots to stick them, cleaned them with Simple Green and let them dry. Then I stuck them (some of the double sided tape didn't take so I had to use a drop or two of wife's nail glue here and there) in place. I fed the wires under the insulation stuff to the switch, soldered and heat-shrinked (heat-shrank? heat-shrunk? whatever. Lol.) them and stuffed them back under the insulation, reattached the switch, and voila! Awesomeness!
Took these at 9 at night with no flash.
URL=http://s128.photobucket.com/user/fayceoff/media/20140326_210651.jpg.html][/URL]
Trust me when I tell you, the pics don't do it any justice. It is SO bright under there... I'm VERY pleased with myself... Hope it helps someone else. If you do it, post a pic here!
"It's almost always cheaper to it right than it is to do it twice." - Dad
"Be polite. Be professional. But have a plan to kill everyone you meet." - Gen. James Mattis
fayceoff is offline
post #2 of 35 Old 03-26-2014, 01:05 PM
rdkendrick
2003 WJ
Thank you, FAYCEOFF. This is a very simple mod that, probably, everyone could use. I don't think I have ever had an under-the-hood light. I can buy these LED strips at AutoZone, but I don't think I have the ball switch. I wonder if AutoZone sells those or a mercury switch?
Sent from my iPad using electrons
rdkendrick is offline
post #3 of 35 Old 03-26-2014, 01:12 PM Thread Starter
fayceoff
fayceoff's Avatar
Why not just pull one from the junkyard?
fayceoff is offline
post #4 of 35 Old 03-26-2014, 01:21 PM Thread Starter
fayceoff
fayceoff's Avatar
Wjjeeps says the light was eliminated after 2001, but you can still buy the harness or install one because the holes and everything are still there.
http://www.wjjeeps.com/hoodlamp.htm
fayceoff is offline
post #5 of 35 Old 03-26-2014, 01:23 PM
its-me-B
I did something similar with mine but I used two 10 stripes left over from another project. I centered them and zip tied them in place and ran a switch off the battery. I'm betting yours is super bright because I know my two will put good light everywhere under there.
Do the world a favor, hurt a honda...
Iro 3" lift with pro comp 9000es shocks, adjustable trackbar, led rock lights, all interior lights converted to leds, two 10" kicker comp with Kenwood 600 watt amp
Zombie Outbreak Response Unit #396
its-me-B is offline
post #6 of 35 Old 03-26-2014, 01:25 PM
KingSmoth
1978 CJ5
thanks for this. I was going to the yard this weekend to pull a light and harness, so this will be an awesome upgrade for a little more money and effort. Not having a light for the engine bay sucks...
2002 WJ Overland - stock
1978 CJ5 - 350, 34's
1990 XJ Laredo - sold...
KingSmoth is offline
post #7 of 35 Old 03-26-2014, 01:32 PM Thread Starter
fayceoff
fayceoff's Avatar
I was surprised to not see anything like it on here. It IS simple, but I hope it helps someone.
fayceoff is offline
post #8 of 35 Old 03-26-2014, 01:45 PM
TURNER76
I was thinking of doing this but did not no If they could handle the heat.Looks cool and functional,I like It.
TURNER76 is offline
post #9 of 35 Old 03-26-2014, 02:27 PM Thread Starter
fayceoff
fayceoff's Avatar
Well, I'm honestly not sure how they'll stand up to the heat over time. We'll see. But for 18 bucks I figured why not give it try?
fayceoff is offline
post #10 of 35 Old 03-26-2014, 02:29 PM Thread Starter
fayceoff
fayceoff's Avatar
Got a pic?
fayceoff is offline
post #11 of 35 Old 03-26-2014, 02:52 PM
jra8858
I thought I was the only one that did that lol. My girls nail glue has gotten me out of some pretty sticky situations before, and it holds forever. Better than any super glue Ive ever used that's for sure. Nice mod BTW
jra8858 is offline
post #12 of 35 Old 03-26-2014, 03:08 PM
ChrisHager
Administrator
ChrisHager's Avatar
Originally Posted by jra8858 View Post
My girls nail glue has gotten me out of some pretty sticky situations...
Pun intended?
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is online now
post #13 of 35 Old 03-26-2014, 04:17 PM
jra8858
[QUOTE=ChrisHager;21599793]Pun intended?
Lol....... no pun intended
jra8858 is offline
post #14 of 35 Old 03-26-2014, 07:23 PM Thread Starter
fayceoff
fayceoff's Avatar
Added some night pics in the OP...
fayceoff is offline
post #15 of 35 Old 03-27-2014, 06:39 AM
Amadauss
Thanks for the write up. Have a 99 and it looks fairly easy to do.
1999 Jeep WJ, 78,072 miles new adco sway bar in rear. new rotors hubs and caliphers, new cv axles up front, Repainted-all black. steering system better stabilizer new tie rods and tubes. New shocks.
Amadauss is offline
engine , engine compartment , hood , light
