Emergeny brake advice? - JeepForum.com
 1Likes
  • 1 Post By CarlJH
post #1 of 6 Old 09-25-2017, 05:39 PM Thread Starter
North_pike98
2004 KL Cherokee
I have an 04 WJ Laredo with the 4.0L. My emergeny/parking hand brake does my work at all, it hasn't worked since I have had the vehicle. The handle still has has plenty of tension in it, for example I'm not able to fully pull back the handle. But I can pull it up about 20 or so clicks. The brake doesn't engage at all. If I apply the e brake amd but it in drive and take my foot off the foot brake, the car rolls the same speed as it would without the hand brake engaged. Thanks for all the help!
Robb Pike
North_pike98 is offline
post #2 of 6 Old 09-25-2017, 06:19 PM
HarryH3
The e-brake has manual adjusters, a star wheel in each side. Have you ever adjusted yours?
HarryH3 is online now
post #3 of 6 Old 09-25-2017, 07:14 PM
BDW
Also if axle seals leak parking brakes get lubed.
04 WJ 4.0/NP242, 3" OME, Bilsteins, 255/75/17 & JKR wheels, 44A, 4.56, ARB lockers, & more
BDW is offline
post #4 of 6 Old 09-25-2017, 10:45 PM
Topher11
Topher11's Avatar
The handle is self tensioning. Like Harry said the only adjustment is on each shoe. Parking brake kits are cheap if you get in there to adjust them and they are shot.
1999 WJ 4.0/6"/CLAs/33s/242SYE/ZJ Rad Swap
2006 LJ 4.0/2.5"/33s
Respected Access Is Open Access. Tread Lightly.
Topher11 is offline
post #5 of 6 Old 09-26-2017, 07:32 AM
CarlJH
2003 WJ
I believe they should start to hold the wheels after the second click of the handle (with it raised off the ground), even working properly they don't work that well.
blueseasons1 likes this.
CarlJH is online now
post #6 of 6 Old 09-26-2017, 12:52 PM
Uniblurb
Uniblurb's Avatar
Since you still feel plenty of tension on ebrake handle it's time to replace your ebrake shoes and they're cheap. I've found about the best tool for removing/installing those shoe retaining clips is a pair of locking needle-nose pliers like vice-grips.
Also when you have the shoes off sand any rust off of the 6 raised metal pads on the dust shield/backing plate the metal part of the shoes rides on. Then put a little lube on them like white or brake grease while lubing the top equalizer a little which pushes the shoes out.
All adjustment is done at the star-wheels on the adjuster unless you're replacing cables which shouldn't be needed. Good luck.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 96 4.0 XJ (son's)
Uniblurb is offline
