Emergency fuel shut off switch located? - JeepForum.com
post #1 of 9 Old 09-03-2011, 10:06 AM Thread Starter
GatorJeep15
Hoping for some quick answers here please
GatorJeep15 is offline
post #2 of 9 Old 09-03-2011, 10:07 AM
tsconver
2003 WJ
there isn't one on the grands
Speak softly and carry a big stick.
We have room but for one flag, the American flag . . . We have room but for one language, and that is the English language . . . And we have room for but one sole loyalty...and that is a loyalty to the American people. T. Roosevelt 1919
2003 Grand Cherokee 4.0L Laredo
A few goodies
2001 Kawasaki 1200 ZRX
A few Speed parts, fun to ride
2006 Red Liberty
Wife's ride, pretty stock
tsconver is offline
post #3 of 9 Old 09-03-2011, 10:10 AM Thread Starter
GatorJeep15
Thanks for the quick response
My grand is clicking when I turn the key but not turning over. I've put gas in but that's not the problem.
Any thoughts to what's the problem?
post #4 of 9 Old 09-03-2011, 10:18 AM
4Tom
Battery terminals or flat batter !
The battery terminals need to be very clean and make tight connection to battery poles.
WJ 2001 3.1TD
Tom
4Tom is offline
post #5 of 9 Old 09-03-2011, 10:30 AM
tsconver
2003 WJ
yeah sounds like a dead battery, could be a failed battery, bad terminals or a bad ground. all are common on grands.
A few goodies
2006 Red Liberty
tsconver is offline
post #6 of 9 Old 09-03-2011, 10:42 AM Thread Starter
GatorJeep15
I can use the radio, lights, and everything else electrical so that's why I think it's not the battery
post #7 of 9 Old 09-03-2011, 10:50 AM
tsconver
2003 WJ
because those are all pretty low draw, it takes a lot amperage to pull the starter solenoid closed and engage the starter. Clicking when you turn the key is very indicative a bad battery or bad connections. Easiest thing is to see if you can jump start it and then take it to autozone or any other parts store and have them check the battery and alternator, most do it free,
A few goodies
2006 Red Liberty
tsconver is offline
post #8 of 9 Old 06-08-2015, 03:24 AM
tom56
my 2000 jeep grand Cherokee turns over has spark and fuel pressure no injector pulse changed the crank and cam sensors any idea why no injector pulse
tom56 is offline
post #9 of 9 Old 06-08-2015, 08:00 AM
Jeeples
Jeeples's Avatar
Which engine?
Also, if you have spark, then spray a bit of starting fluid in the throttle body and see if it fires up. If it does then you know for sure that you have a fuel system issue.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
Where is the fuel pump fuse located? novellof WJ Grand Cherokee Forum 4 05-02-2015 03:22 PM
Where is the PVC Valve Located? 2002 4.7 L AndyJeep WJ Grand Cherokee Forum 2 03-29-2011 04:55 AM
Where is the fuse located for the heater blower on a 2000 Grand Cherokee Limited? hick2087 WJ Grand Cherokee Forum 3 01-18-2011 04:07 PM
Ordering new PCM; where is it LOCATED?!?!? Joshcop WJ Grand Cherokee Forum 3 10-19-2010 04:45 PM
Emergency studstill1 WJ Grand Cherokee Forum 3 09-06-2010 02:16 AM
