Electrically dead as a door nail, Thoughts? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Electrically dead as a door nail, Thoughts?
Rampage Bowless Soft Top Oconee offroadAlloy USA Still AvailableAdvance Adapters SYE Kits
Unread 09-18-2014, 07:45 PM   #1
PatriotBlue02WJ
'02 Grand Cherokee, 4.7...
I drove to work this morning, no issue. Drove it at lunch time, no issue. Went to drive home from work, I was able to unlock the doors with the fob, I got the key in the ignition, slight turn, I hears a small click (not the click of a dead battery, more of an electronic click in the dash), and got nothing when I finished turning the ignition. Everything is dead. Had a buddy try and jump it, it made no difference. I checked the voltage across the battery, 12.8V. I don't have a dome light, radio, absolutely nothing. I can't even lock/unlock the car with the fob anymore. I had to leave it at work, I'll troubleshoot a little more tomorrow, but where do you think I should look? My first thought was bad cell in the battery, but I have absolutely no power getting to any part of the car (I'd think something would work, it just wouldn't have the cranking power). Second thought was a bad tumbler in the ignition switch, but again, I would think I'd still be able to lock/unlock the car. The fact that the fob isn't even working is puzzling me. Thoughts?
PatriotBlue02WJ is offline   Reply With Quote Quick reply to this message
Unread 09-18-2014, 08:09 PM   #2
champ926
Same thing happened to me. Turned out to be a loose battery terminal. Also check the ends of the battery cables as they corrode (turn green) resulting in a poor transfer of current.
champ926 is offline   Reply With Quote Quick reply to this message
Unread 09-18-2014, 10:10 PM   #3
cykaaro
Yep, and typically it's because it's not getting a good or proper ground. Went through it myself last year.
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline   Reply With Quote Quick reply to this message
Unread 09-19-2014, 05:22 AM   #4
PatriotBlue02WJ
Thanks, I'll try at that when I get back to work. They didn't look bad at all, from some searching on here, it looks like a common problem. I had a dream last night thats all it was. Lets hope!
Unread 09-19-2014, 06:48 AM   #5
Darnice
Exact same thing happened to me, The terminals "Look" clean, but when i removed it, the inside of the negitive battery terminal connector (not the post) had disintegrated inside itself.
It was just a shell with no insides left. Had to replace it, wen to a marine style (wingnut and soldered on terminals)
I also, because it was 5 years old, replaced the battery with a 1000CCA AGM battery. The jeep starts instantly now and runs great.
Darnice is offline   Reply With Quote Quick reply to this message
Unread 09-19-2014, 08:46 AM   #6
PatriotBlue02WJ
Figured it out. Connections were clean, but the wire I marked below was hanging on by a thread of copper. Re-terminated it and it got me home. Picked up a new battery terminal and cleaned up the wiring when I got home. I'm hoping this was also part of my occasional hesitation issues. We'll see, seems good now. Thanks for the input!
