Electrical system/computer goes haywire - JeepForum.com
post #1 of 2 Old 05-15-2002, 08:06 PM Thread Starter
SRT99WJ
Post Electrical system/computer goes haywire
I joined this forum last week with a sound system issue, and now my electrical system is having serious problems. Prior symptoms: None. Got in this afternoon, turned the key, no starter noise just one click. Then all my guages began to spin back and forth, accompanied by a clicking/gear grinding sound; accessories and clock didn't function.
This continued after the key was removed. So I had to pop the hood to get at the battery; the underhood light was dim and pulsating, like it was still sending power to the starter, trying to get it to crank. I thought it might be a computer glitch so I disconnected and reconnected the battery only to have the problem continue.
Of course this happens when the car is only 7000 miles outside the warranty period. Has anyone experienced anything like this? I'll be calling the tow truck in the morning. Any help is greatly appreciated!
Stephen
1999 Grand Cherokee Laredo
4.7L V8 Quadra-Drive
Bridgestone Dueler AT's
K&N FIPK Gen II Intake
SRT99WJ is offline
post #2 of 2 Old 05-17-2002, 06:48 PM
moabster
moabster's Avatar
2011 WK
Post
Check the battery. When my battery went bad on my 93 Grand Cherokee it acted about the same. Next check starter to see if it is shorted. Did you recently install a stereo system? If so, check wiring to make sure you don't have something draining the battery when the jeep if off.
2000 Jeep Grand Cherokee V8 Stock
93 YJ I6 hard top (really belongs to SPEED)
RE 4.5" Extreme Duty Lift, Advanced Adapters SYE, Tom Woods CV Drive Shaft, EA589 10" rims with 33" x 12.5" MT/Rs
Bullet Proof Front and Rear Bumpers and Tow bar
moabster is offline
Service Electrical Brake System light? beeneeb WK Grand Cherokee & XK Commander Forum 14 06-23-2015 02:02 PM
Electrical System is PO'd xa310165 WK Grand Cherokee & XK Commander Forum 11 10-22-2009 03:13 PM
Possible electrical/charging system issue. GCherokee2001 ZJ Grand Cherokee Forum 0 11-08-2007 01:25 PM
Electrical System Problem MWLThe1st ZJ Grand Cherokee Forum 3 01-22-2007 02:19 PM
Electrical system? rpeAMP ZJ Grand Cherokee Forum 1 10-20-2002 11:44 PM
