Electrical problems? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Electrical problems?
Custom Tire covers for your Jeep at Jeephut.comThe Spring DynoMax rebate is here for 2015!New wheels at Jeephut.com
Unread 02-26-2015, 11:55 AM   #1
brotherflash
Just bought a used 2000 WJ Laredo. Having problems with the cruise control working intermittently, also volume on stereo randomly goes up or down. Alarm for low washer fluid constantly goes off every few miles even though it's full.also drivers side seat belt brake is tuck and is very hard to put on, constantly have to let it go pull let it go and pull to get it buckled. Coincidence that all these issues are happening at same time or is there a common sensor or electrical issue? Any advice would be greatly appreciated
brotherflash is offline   Reply With Quote Quick reply to this message
Unread 02-26-2015, 12:47 PM   #2
JTS97Z28
Cruise control issues are common and they say check all the vacuum lines under the hood. Follow the one that connects to the throttle body (atleast on the V8). It then runs up against the firewall and into some hoses that run up to behind and under the passenger headlight. People say that if these hoses are disconnected or broke cruise control will not work. Also, check all the fuses in the driver footwell as well as under the hood by the battery. Since its an intermittent problem and if you don't see anything obviously wrong with the vacuum hoses, then maybe something wrong with one of the switches on the steering wheel? Not sure.
Volume issues, not really sure but I would guess probably a defective headunit. Those are cheap and easy to replace.
Alarm for low washer fluid. I can only imagine its the sensor on the reservoir.
Seatbelt issue sounds like its all in the mechanism behind the panel. Either replace it or take it apart and see if anything looks broken.
As far as common electrical issues....Yes you guessed it. The WJ does have a *** load of "common" issues. Whats cool about these rigs is there are soo many DIY's and a lot of the things can easily be fixed in your garage. The most common electrical issue I know of is the broken wire issue that occurs in the drivers door boot. When you open the door all the way the black rubber boot that houses the wires that run from the body into the door. After years of use a wire or two in there split and cause all sorts of weird issues. They says its usually this one black wire that splits. Things I have personally seen happen due to this is interior lights don't go off, power windows dont work, door locks dont work etc etc. So none of the issues you mentioned seem related to the broken door boot wire, but could be worth checking into since its pretty easy to tackle.
The cool things about the WJ's is all you have to do is a quick google search and tons of threads and videos (youtube) come up with how to's. So do some searching for each issue and there is a good chance there is info about it online.
JTS97Z28 is online now   Reply With Quote Quick reply to this message
Unread 02-26-2015, 02:47 PM   #3
brotherflash
Thanks so much for the tips
Unread 02-27-2015, 10:27 PM   #4
Jameswj2001
Generally, I'd recommend unhooking your battery for a few minutes to reset everything. Works wonders on these wj's... Good luck!
01 WJ 4.7 quadra drive 2" bb 245/70/17 grabber at2's
00 XJ 3" lift Wrangler authority 31 10.5 15
Jameswj2001 is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 12:14 AM   #5
rep-tile
Define "cruise working intermittently".
If you have volume buttons on the back of the steering wheel; they could be one of your issue.
04 WJ
91 XJ
rep-tile is offline   Reply With Quote Quick reply to this message
