Electrical Problem No Start - Help! - JeepForum.com
post #1 of 3 Old 07-19-2013, 06:50 AM Thread Starter
iudelt89
So my WJ has been doing some strange things recently, and finally will not start without a jump. A few weeks back I turned on the ignition and the guages started jumping around all over the place and it wouldn't start. No clicking, literally nothing. I turned the key to accessories on and off a few times, let it sit for a minute or two, then it reset itself and started. Everything worked, all power options, radio, guages, etc.
After that point however, the trip meter, avg mpg, and pretty much everything in the overhead computer kept resetting randomly when I would turn the car off then on again. Once it was running though, everything was fine and worked normally.
So fast forward to this morning. The car won't turn over at all, and the guages are bouncing all over the place even when the key is not in the ignition. The interior lights came on, but are extremely dim. There is a clicking sound coming from one of the relays behind the fuse box in the driver's side footwell. I tried disconnecting the battery for a while, no dice. I was able to jump it, and once started, everything worked fine again. As soon as I turned the car off again, the guages started boucing all over the place even with the key out, and once again it will not turn over at all.
I had the alternator and battery tested a couple weeks ago after the first incident, and everything was fine. They recommended I replace the PCI bus and guage cluster due to what I was describing. I was thinking this might be a PCI bus issue, but the symptoms don't match what I've read about it. I don't want to replace the guage cluster, because it works perfectly when the car is running. I'm thinking it could be a bad relay because of the clicking sound, but then why would jumping it work? I am completely at a loss here and I can't seem to find anything about this happening on the forum. Anyone have any ideas as to what this could be?
2000 WJ, 2004 Mach 1 Mustang
"Though I walk through the valley of the shadow of rice, I shall fear no import. For torque arte with me."
iudelt89 is offline
post #2 of 3 Old 07-19-2013, 07:02 AM
PumaZJ
Still sounds like a battery issue.
1998 ZJ - 36's & bent unibody - RIP
2004 WJ - Expedition build
2011 A4 - DD
PumaZJ is offline
post #3 of 3 Old 07-19-2013, 07:31 AM
cykaaro
Absolute first thing you should do is throughly clean battery cables, and connectors, and then make sure they're tight. Next do the same to the ground on the engine block which comes from the battery. As well check the ground strap that goes from the back of the engine to the firewall. Make sure it's intact, clean and tight. Once this is done, is there any difference in what you're seeing? (although doesn't rule out a bad cable itself)
First thoughts are you could have a ground issue, or somethings grounding/shorting out making things go haywire. Start with the simplest and easiest to do things first and then go from there.
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
