Electrical Problem? - JeepForum.com
post #1 of 8 Old 05-01-2013, 07:32 AM Thread Starter
Tdh24
Electrical Problem?
Hey everyone
I have a 2004 Grand Cherokee and today after I turned it off from parking it in parking spot the battery gauge needle and the gas gauge needle started bouncing around like crazy. Going up to max then back down. I tried to start it again and nothing. It doesn't try to crank at all and no electronics work at all (radio, locks, horn, nothing). I checked the ignition and accessory fuses and they looked fine. Could this be a battery? I have never had a battery go out this fast and this intense where not even the locks work. The battery in the Jeep is about 3 years old and is and Advance Auto Gold (Didn't want this brand, but its the only auto parts store in my college town) Any advice would be appreciated.
Tdh24 is offline
post #2 of 8 Old 05-01-2013, 07:41 AM
ChrisHager
Administrator
ChrisHager's Avatar
Clean your terminals and reinstall/tighten the crap out of the connections.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline
post #3 of 8 Old 05-01-2013, 07:47 AM
brianestep
Originally Posted by Tdh24 View Post
Hey everyone
A quick search yielded 2 NAPA's, 3 Autozones and an OReilly's in Raleigh... Just sayin. While most of Autozones stuff is arguably (or maybe not arguably) inferior to anythig NAPA has, their Duralast Gold batteries are decent, and come with a pretty good warranty as well.
-Brian- 2000 WJ Four liter, 4" RC springs; Bilstein 5100s; JKS trackbar w/KOR bushings; Stillen rotors; KOR (RC) 1.5" wheel spacers; 265/75/16 Treadwright Guard Dogs; Rusty AirTube, Amsoil Cone; Thule M.O.A.B.; Bumper delete; rear seat disco
brianestep is offline
post #4 of 8 Old 05-01-2013, 07:49 AM Thread Starter
Tdh24
My college town is Boone not Raleigh, that's my hometown. It was a Sunday and the NAPA here is closed...
Tdh24 is offline
post #5 of 8 Old 05-01-2013, 08:33 AM
brianestep
My mistake friend. Appalachian State? Sears Diehard gets good reviews too, depending on the model. Check your terminals as stated above, then get it tested.
post #6 of 8 Old 05-03-2013, 10:28 PM
Tyballski
My jeep has done the same thing. Your battery should be fine, the issue comes from the black ground wire located in the driver side door (in the boot.) The wire may be loose so you need to check the wiring. I could be wrong, but it sounds like the same thing that happened to me.
Tyballski is offline
post #7 of 8 Old 05-04-2013, 05:05 AM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
First time I have heard of that happening with the ignition off.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #8 of 8 Old 05-04-2013, 09:44 AM
heitzman
The battery connectors "Positive and Negative sides" will probably need replaced. Jeeps are known for this. Just cut them off and replace with new ones. I have done it to both of mine, 1999 and 2004.
heitzman is offline
