Electric window stopped working - JeepForum.com
post #1 of 10 Old 07-02-2013, 08:53 PM Thread Starter
jabberpunch
2004 jeep grand cherokee. I've read several posts where all windows stopped working, but in this case only the driver's side rear window won't work (either from driver seat or back seat). Had the wiring harness in the driver door replaced a couple of years ago. Would like to fix myself, where to start?
jabberpunch is offline
post #2 of 10 Old 07-02-2013, 10:39 PM
03azwj
2003 WJ
Could be the regulator.
3" OME HD springs, Bilstein 5100, JKS adjustable trackbar, Moog SS, IRO UCA'S & LCA'S, 3/4" front and rear spacers, BFG M/T km LT255/75R17, JK Rubicon takeoffs, 8K HIDS Hi's & Lo's. full Rockford Fosgate set-up, blue l.e.d. interior, clumsy driver
03azwj is offline
post #3 of 10 Old 07-03-2013, 08:38 AM
rdkendrick
2003 WJ
http://www.1aauto.com/auto-repair-installation-videos
Enter Make, model, and year, find the video on how to replace the window regulator.
It's a start and once you have the door panel off, you should be able to determine what's wrong.
Good luck.
Sent from my iPad using Forum Runner
rdkendrick is offline
post #4 of 10 Old 07-03-2013, 06:10 PM Thread Starter
jabberpunch
Can't get to this until the weekend, but thanks a bunch...sounds like a good place to start!
post #5 of 10 Old 07-03-2013, 09:33 PM
trekra
Also, simple check- pull the boot that houses the wires between the B pillar and the rear door. Inspect the wires. My right rear did the same thing while on a business trip. Several wires looked like they had been cut clean- either pinched or just wore through quite cleanly. I still need to get in and fix them (maybe tomorrow), but it was easy to temporarily make the connection and try the window switch, which worked great.
trekra is offline
post #6 of 10 Old 07-04-2013, 10:57 AM
heitzman
I bet you have a broken wire in the drivers door jamb boot.
heitzman is offline
post #7 of 10 Old 07-04-2013, 11:02 AM
RhinoChaser
ditto,, happened to me 3 times. It was the Orange wire. All windows stopped working and dome light wouldn't turn off.
RhinoChaser is offline
post #8 of 10 Old 07-19-2013, 08:50 AM
1Aauto
Vendor
1Aauto's Avatar
I have an 04, and I've had the darn harness wire plug end loosen up 3X over the past 6 years. Mine loosens up under the driverside kick panel, killing the power to the door. Try to reach in there too and wiggle the harness while pressing the window switch. If your window regulator is cooked, we carry new ones. Here's a link to them on our website for yah. Jeep Grand Cherokee WJ Window Regualtor
1Aauto is offline
post #9 of 10 Old 07-28-2013, 12:09 AM Thread Starter
jabberpunch
You guys were spot on! It was a broken wire in the harness in the drivers door - I didn't think that would be the case because I had a bunch of wiring in there replaced about 2 years ago. Thanks for all the help!
post #10 of 10 Old 08-19-2013, 08:28 AM
theonlyrobertso
2014 JK Wrangler
theonlyrobertso is offline
