Electric fan to replace mechanical fan - Page 2 - JeepForum.com
post #16 of 32 Old 09-13-2013, 06:16 PM
narnwv
narnwv's Avatar
Originally Posted by rdkendrick View Post
I only have the mechanical fan on my Overland with tow pkg. I assumed this was normal?
Sent from my iPad using my fingers
All 01+ v8s have a hydraulic fan driven off the power steering pump.
Typing on phones sucks.
~Aaron
narnwv is offline
post #17 of 32 Old 09-13-2013, 07:11 PM
rdkendrick
2003 WJ
Originally Posted by perfeng702 View Post
you have the hydraulic fan driven off the p/s pump. it was changed in 02 or something like that.
Yes, thanks for the correction, hydraulic fan, that's what I meant. Might be time to go back and study wjjeeps.com.
rdkendrick is offline
post #18 of 32 Old 09-13-2013, 08:20 PM
dlundblad
2003 WJ
I might be all wet, but in the MJ/ XJ world guys will remove the mechanical fan and replace them with an electric duel ford Taurus fan. They fit right in.. Their motive is to gain back the power the engine used to run the fan. I imagine they'd be the same way in the WJ.
03 WJ Laredo 4.Sl0w
2" BB, Overland Skids
2nd set of 245/75/16 DuraTracs
dlundblad is offline
post #19 of 32 Old 09-13-2013, 09:04 PM
narnwv
narnwv's Avatar
I run the Taurus fan setup in my WJ.
~Aaron
narnwv is offline
post #20 of 32 Old 09-13-2013, 11:17 PM Thread Starter
rloew275
What year of Taurus?? How'd you mount it?
rloew275 is offline
post #21 of 32 Old 09-14-2013, 06:19 AM
dlundblad
2003 WJ
Yeah you've gotta post pics and specs now. Lol.
03 WJ Laredo 4.Sl0w
post #22 of 32 Old 09-14-2013, 08:31 AM
SteelBlue_WJ
SteelBlue_WJ's Avatar
yeah you've gotta post pics and specs now. Lol.
+1
Bobby
2001 Steel Blue WJ Laredo SA 4x4, 3.5" lift, Apperance Package with factory Laredo Steel Blue cladding/leather
Conferr Roof Basket with custom Randy Ellis Design light cage, WAAG grille guard and Hella lots of 500 lights
2004 Wrangler Sport, 2.5" and 31's, nothing special
"For all sad words of tongue and pen, the saddest are these, 'It might have been.' "
John Greenleaf Whittier
SteelBlue_WJ is offline
post #23 of 32 Old 09-14-2013, 12:07 PM Thread Starter
rloew275
Yes! Pictures! Also, how can I test my electric fan to make sure it's working alright? What circumstances does it need to kick on?
rloew275 is offline
post #24 of 32 Old 09-14-2013, 01:06 PM
Jaspah
It should always turn on when the A/C is on (it might take a few seconds after hitting the button).
Jaspah is offline
post #25 of 32 Old 09-14-2013, 01:29 PM Thread Starter
rloew275
Alright, pretty sure I need a new relay then. On another note, I'm unable to remove my itch fan, the belt just slips on the water pump and I can't break the nut Loose.
rloew275 is offline
post #26 of 32 Old 09-14-2013, 07:15 PM
rdkendrick
2003 WJ
You might have to scratch it some. :-D
post #27 of 32 Old 09-14-2013, 07:29 PM Thread Starter
rloew275
Hahaha! Gotta love autocorrect!
rloew275 is offline
post #28 of 32 Old 09-14-2013, 10:51 PM
WJ2000
So Iam just a confused , I don't thank you just remove your hydraulic fan, and replace it with an electric duel ford Taurus fan
and''''' did you install it, right on the back of the existing electric fan ??? . So whats wrong with this picture , is it that, the stock
Jeep electric fan sucks , or you have two electric fans stacked on top of each other ?? Some one please clarify , no one has said to
remove the stock jeep fan '' at all . Just the Hydraulic one .
2000 WJ 4.0 NEW 4.6 stroker. W/ 4'' Tera Flex Long arm kit, KING 2.5s w/res front,2.5 Kings w/res Rear,Tom wood front drive, 33 x 15s KM2s, Bassett 15'x8 ,fully addjustible Tera flex Track bar, IRO 3link rear, EBC Dippled & sloted front disks, EBC green stuff pads, Iceland off road fender flairs''.
WJ2000 is offline
post #29 of 32 Old 09-15-2013, 12:35 AM
gcjeeping
gcjeeping's Avatar
If you remove the hyd fan you will probably get codes unless you can fool the jeep in thinking its still there.
_____________
gcjeeping is offline
post #30 of 32 Old 09-15-2013, 10:16 AM
WJ2000
So how did you set this up, Please read my last post ''
Thanks Man ''
WJ2000 is offline
