-   WJ Grand Cherokee Forum (http://www.jeepforum.com/forum/f310/)
-   -   Electric fan to replace mechanical fan (http://www.jeepforum.com/forum/f310/electric-fan-replace-mechanical-fan-1579505/)
rloew275 09-12-2013 04:14 PM
So I have a 2001 Wj 4.0 and i'm pretty sure my cooling fan clutch is failing, as it stays engaged at all times, and at all speeds/RPM's. So i was looking at replacing the fan clutch itself, and then i started debating other options, such as replacing the mechanical fan with an electric one and just wiring it to a switch on the dash. I also contemplated just removing the mechanical fan and just running the electric one, although i don't wanna risk overheating.
My main reason for swapping out the fans would be to gain a little more power... which i know this has been a debate on here in a couple of threads already, but heres how i know i will gain some power.
- Starting a couple months ago(when I'm guessing the fan clutch started failing) everytime my engine would get around 3000 rpm, my belt would start to squeal.. after investigating it more i noticed when the belt started to squeal the fan would quit accelerating in speed although the engine would continue to accelerate, so i figured the fan was causing the belt to slip on the pulley. well when this would happen, my jeep would lunge forward more and get a little boost. so i am pretty sure i can get some more power
Another reason is because a new fan clutch is $55 around here, and i thought that maybe i could find a decent electric fan for the same price if not cheaper.
SSOO..... What fan would be good for this? are there any replacement kits? is there a specific vehicle i could pull one off of that would work in place of the mechanical one? how should i mount it? what have other peoples' experiences been with this??
just looking for some tips or advice before i start into something.
Thanks in advance! Jeep on!
Bandit84 09-12-2013 07:15 PM
Our 2001 has a electric and mechanical fan from the factory. I have no idea if it still works. But I'm sure you can find one in a upull yard
Jaspah 09-12-2013 07:20 PM
You should have both the electric fan and the mechanical fan. I have both. My electrical one didn't work until I replaced the fan relay.
rloew275 09-12-2013 07:40 PM
Yeah I have both, but the electric fan isn't designed to pull enough air to the engine on its own... So I wanted to replace the mechanical one with a larger electrical one. Something of that sort, or can I just pull the mechanical one ?
Jaspah 09-12-2013 07:54 PM
...Yes it is. The mechanical fan was only bundled with 4.0 WJ's equipped with the tow package. It's completely optional.
WJChris01 09-12-2013 09:03 PM
My WJ does not have the tow package and it has a mechanical fan.
Jimbo_IX 09-12-2013 09:22 PM
When my electric fan disintegrated, I replaced it with a mechanical one. I am much happier with the mechanical one that is always moving air. I've been through 3 South Texas summers with it, and even drove 560miles through the "badlands" to El Paso. Never got above normal temp.
rloew275 09-13-2013 07:17 AM
Well I don't haul anything with mine, most of my driving is 55mph+ so I'm not worried about it over heating... If I feel it is getting too warm then I might put a cooler thermostat in, but now I'm thinking of just pulling the mechanical fan altogether and see how that goes for now,
gcjeeping 09-13-2013 01:10 PM
Yes it is. My 4.0 only has the elec fan and has never had a over temp problem. I've lived in Tucson and New Mexico with it too. If you have a problem with temps you may have other problems. I used to tow a 16' boat in AZ in the summer without problems.
gcjeeping 09-13-2013 01:16 PM
Why do you think a cooler thermostat would help? Whether you have one that opens fully at 175, 185 or 195 your engine should never get much above 210. If it overheats above 220 it doesn't matter what thermostat you had in because it was fully open by 200.
Also your engine is designed to run at a certain temp. Running a 175 may not allow your engine to reach peak temp during cold weather leading to poor performance and bad fuel economy.
rloew275 09-13-2013 01:19 PM
Thanks for the Input!! I think I'll just pull the mechanical fan and leave it at that.
Jaspah 09-13-2013 01:28 PM
Semantics! AFAIK, it was optional regardless. You could either get the tow package and have the fan come with it or order it separately. It may have also been a special edition kinda thing. Not sure.
rdkendrick 09-13-2013 02:53 PM
I only have the mechanical fan on my Overland with tow pkg. I assumed this was normal?
Sent from my iPad using my fingers
metalhead 09-13-2013 03:04 PM
I removed the mechanical fan and just run the stock electric fan. Have never had a problem yet with overheating.
perfeng702 09-13-2013 04:18 PM
you have the hydraulic fan driven off the p/s pump. it was changed in 02 or something like that.
The time now is 03:02 AM.
