Eating shock bushings - JeepForum.com
post #1 of 8 Old 07-02-2013, 03:26 PM Thread Starter
JustStew
Hey guys, had my IRO lift on for a few months and out about 2000 miles on it. The problem is when I beat on it off road...mostly sharp jarring bumps on fire roads and some pretty decent flexing other times it eats lower front shock bushings. I've replaced em twice now. This is what they look like when they start clunking over every little sharp bump.
JustStew is offline
post #2 of 8 Old 07-04-2013, 01:43 AM
cykaaro
What do you replace them with? I've had good luck with energy suspension ones.
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #3 of 8 Old 07-04-2013, 07:16 AM Thread Starter
JustStew
Just been using the stock style, maybe ill try a poly type
JustStew is offline
post #4 of 8 Old 07-04-2013, 08:15 AM
cykaaro
Changed all my back shock bushings to energy suspension as mine were in really bad shape. Been fine since.
cykaaro is offline
post #5 of 8 Old 07-04-2013, 10:28 AM
MuddyWJ
Have you tried twisting your shock till it sits square to the BPE?
MuddyWJ is offline
post #6 of 8 Old 07-05-2013, 12:31 PM Thread Starter
JustStew
Tried to get them square to em but after a few miles they shift. Checked alignment and axle placement.
JustStew is offline
post #7 of 8 Old 07-05-2013, 06:47 PM
MuddyWJ
Throw a washer on each side a little bigger than the bushing. Just make sure to grease them.
MuddyWJ is offline
post #8 of 8 Old 07-06-2013, 05:50 PM Thread Starter
JustStew
Might give that a shot, thanks guys
JustStew is offline
