Dual fans? - JeepForum.com
post #1 of 5 Old 06-09-2014, 07:01 PM Thread Starter
JMZ101586
Dual fans?
My 4.7 only has a single electric fan. Is it possible to install the clutch fan with it? I read cars with the tow package had both and my water pump is threaded but it looks very narrow between it and the e-fan bracketing.
JMZ101586 is offline
post #2 of 5 Old 06-09-2014, 08:14 PM
fast540
Yes
fast540 is offline
post #3 of 5 Old 06-09-2014, 08:19 PM
narnwv
narnwv's Avatar
your 4.7 does not have an electric fan at all!
From 2001 and up, all the v8s have a Hydraulic fan--powered by the power steering pump. It's the most efficient, effective cooling solution for these beasts.
~Aaron
narnwv is offline
post #4 of 5 Old 06-09-2014, 08:19 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
It is very close, but it does fit.
Sometimes they're hard to get into the shroud, I separate the fan from the clutch on the workbench, then pass each piece past the engine into the radiator shroud & reassemble them in place.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #5 of 5 Old 06-09-2014, 08:35 PM Thread Starter
JMZ101586
Wow didn't realize it ran off the ps pump. I'm a GM guy so I'm learning a lot. I've just read a lot about 4.7 overheating and thought it a worthwhile mod to have a clutch fan.
