Dual Climate Control light bulb blew - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Dual Climate Control light bulb blew
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineEngo winches available at www.rockridge4wd.com! Free shipp
Unread 04-28-2011, 04:27 PM   #1
adgjqetuo
So I saw this morning that one of my lights on the dual climate is burned out. At first I thought it was no big deal, but after reading WJJeeps, it looks like they aren't really replaceable.
Has anyone had to do this before? If so what steps did you take? It looks like its going to be a pain. Why can't it be like my old ZJ where they were easy to replace?
http://www.wjjeeps.com/lamps/lampsrem.htm
Mike
13 Subaru Outback Limited - Current
04 Jeep grand Cherokee Overland - 23k ~ 71k - Sold
98 Jeep Grand Cherokee Laredo SE - 73k ~ 150k - Sold
adgjqetuo is offline   Reply With Quote
Unread 04-28-2011, 06:33 PM   #2
straty1987
there changeable just a a PITA
i notice my bottom light on the left side knob is light just as. juts i think finding the replacement bulbs will be the hardest part there 5013123AA
Eight climate control lamps are soldered onto the internal circuit board of the Automatic Zone Control assembly.
straty1987 is offline   Reply With Quote
Unread 04-28-2011, 06:52 PM   #3
CarlJH
the bottom left one on mine has gone, was going to take a look this weekend,having seen this its going to stay broken!
CarlJH is offline   Reply With Quote
Unread 04-28-2011, 07:23 PM   #4
straty1987
yup just try not to think about it n wont notices it
Unread 04-30-2011, 06:08 AM   #5
pdpunome
it is really not difficult just take your time and be patient little things like that will eat you up over time and you will end up doing it any way thats how it always happens.
pdpunome is offline   Reply With Quote
Unread 04-30-2011, 12:19 PM   #6
straty1987
you have to be able to solder since they are solder onto a circuit board. if you mess up the link can destroy the unit or make things worse.
also have to find the bulb, no auto store by me had it and at dealer its around $2
its mostly a thing a person will want to do but not needed. theirs a boatload of other things that probably need to be done before this bulb on any of our wj's.
like the led not working on the heated switch, they go out but it still works
Unread 08-20-2012, 05:59 PM   #7
sato
Climate Control Lights and Shifter Console Lights
I just purchased a USED WJ 2004 limited and noticed both the Shifter lights and the Climate Control lights are completely out. I read about what is needed to replace these and was hoping someone might know if there is a fuse that would cause this behavior? I do not want to take everything apart and then find out 1 fuse controlled all these light bulbs. All other lights work except the Radio seems to be completely dark except the display but this is my first WJ so I am not sure if that is normal.
sato is offline   Reply With Quote
Unread 09-03-2012, 09:38 PM   #8
sato
Fuse #6 appears to control the back lights on the climate control, shifter console, and radio. I replaced the fuse and all lights are now working. Glad it was just a fuse as I was getting ready to take apart the dash and shifter. FYI, wjjeeps.com lists this fuse as park lamps.
Unread 01-04-2013, 07:36 PM   #9
04WJLIMITED
I too have a an 04 WJ Limited. However all the lights are on except for the right side of the climate control knob and the passenger heater switch is off. The heater switch still powers on the seat heater. Just noticed this today, haven't driven it at night in a while so not sure how long it has been like this. I have read that some people say its easy to replace the bulbs and other say that you have to solder them back in and if you mess it up you can ruin the control circuit.
GC Rough Country 4 in. suspension/RC adjustable lower control arms/RC 1 1/2" wheel spacers, Skyjacker Hydro 7000 shocks, Skyjacker quick disconnects, JKS adjustable trackbar, Falken Rocky Mount (LT285/70R/17). Winch incline bumper with Engo 9K winch-
04WJLIMITED is offline   Reply With Quote
