Dry bearing noise in rear end - JeepForum.com
post #1 of 5 Old 04-24-2013, 10:41 AM Thread Starter
KrisGarner
I am the Reaper
KrisGarner's Avatar
Wj Dry bearing noise in rear end
My "new to me" 2002 Laredo has a noise coming from somewhere in the rear that sounds like a dry rubbing.
I especially hear it at low speeds, when decelerating. At other times, it is still there but not quite as loud. When slowing down, it's not a steady grind, but it kind of pulses, like something is warped. It's not a howl, more like I'm dragging a cardboard box underneath the Jeep. At other times, it is still there but not quite as loud.
I was having some grabbing in the rear when turning, so I replaced the diff fluid and added the Mopar additive. That seems to have cured the grabbing, but not the noise. I didn't notice it when I bought it and have put about 1k miles on it since then and the noise seems to be getting louder. The rear wheels don't seem to have any play like with a bad wheel bearing.
Specs: 2002 Laredo, 4.7, auto, 2WD, 150k miles
Where do I start? Brakes dragging? Wheel bearings? Carrier/pinion bearings?
I talked to Kolak a few days ago about tires and lift, (which I plan on doing in the next couple of weeks). I am going with the IRO 3" and some taller tires to get away from the soccer mom look. I would like to replace whatever is making the noise while I have it all apart for the lift. Plus I want to fix it before I put more stress on it with tires and lift and seriously damage expensive parts.
KrisGarner is offline
post #2 of 5 Old 04-24-2013, 04:01 PM Thread Starter
KrisGarner
I am the Reaper
KrisGarner's Avatar
Also, according to the Mopar Owner site, my VIN came up with:
5-Spd Automatic 545RFE Transmission
3.73 Rear Axle Ratio
Dana 44/226MM Rear Axle
Vari-Lok Progressive Rear Axle
post #3 of 5 Old 04-26-2013, 07:55 AM Thread Starter
KrisGarner
I am the Reaper
KrisGarner's Avatar
Anybody have the same issue?
post #4 of 5 Old 04-26-2013, 08:08 AM
shockracer
I currently have a pulsating scrapping sound now pinpointed to the drivers rear. I think it is the wheel bearing but not 100% sure yet.
2001 WJ 60th anniversary edition 4.7 quadra-drive
5" hybrid lift, 265/70/17 Guard Dogs load E, bilsteins 5100's, addco sway bars, JKS front quick disco's, JKS adjustable track bar, KOR durometer track bar bushings, IRO crucial path front L.A.s, 1.25" Spidertrax spacers
Colorado Jeep Club Member #262
shockracer is offline
post #5 of 5 Old 04-26-2013, 08:17 AM Thread Starter
KrisGarner
I am the Reaper
KrisGarner's Avatar
Mine sounds about the same and from the same side. I just put in my order with Kolak for the IRO 3" lift, so I guess I'll find out where it's coming from soon.
