First off hello all, this is my first post here. PLEASE bare with me as I have been building and wheeling IH Scouts for years and just recently aquired my WJ.
I did some research on previous threads on here regarding this topic but want to be clear. Sorry for beating a dead horse.
I have a bad joint (rezappa ?) At the TC end of my front drive shaft. I realize this is a common problem and the whole shaft should be upgraded to a CV at the TC and standard U joint at the axle correct me if I am wrong.
I have seen shafts from Rustys but don't want to pay an arm and a leg. I read that going with a 04 WJ drive shaft with the correct set up will work is this correct ? Aside from Yokes is there anything else needed?
Also at what lift height do u all recommend longer than stock drive shafts?
Sorry for the book, Thanks for your time
