Driveshaft - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Driveshaft
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder Brawler MID Front Bumper for JKSuper Low Prices on TJ Bumpers and $399.95 Tire Carriers!
Unread 01-14-2011, 08:57 PM   #1
MStaffin
MStaffin's Avatar
Driveshaft
Ok will my 97 zj drive shaft fit in my wj both motors trans tcase and rears are the same so will it work till I can press out my u joint?
MStaffin is offline   Reply With Quote
Unread 01-15-2011, 04:48 PM   #2
MStaffin
MStaffin's Avatar
anyone know
Unread 01-15-2011, 06:21 PM   #3
TJSWJ
TJSWJ's Avatar
If its the dbl cardon u joint style than I know it will. I'm running one now. Not sure about cv style shafts though.
www.xjor.org
TJSWJ is online now   Reply With Quote
Unread 01-15-2011, 08:14 PM   #4
MStaffin
MStaffin's Avatar
I have 2 u joints one at front right after tcase and one at back right b4 rear is that the dbl.??
Unread 01-15-2011, 08:38 PM   #5
TJSWJ
TJSWJ's Avatar
No that's single. But it will work for you.
www.xjor.org
Unread 01-15-2011, 08:40 PM   #6
MStaffin
MStaffin's Avatar
So I can replace it with it cause its same motor same tcase and axle I dont see why ill give it a try its only till I can get to the press at work to press the u joint on my wj axle as it frove solid and the clips broke off but the caps did not move even with heat. I think thats giving me half of my jerky problem.
Unread 01-15-2011, 08:45 PM   #7
TJSWJ
TJSWJ's Avatar
Yeah you can swap it. I don't believe they are exactly the same drive shaft. But like I said, I'm running a Zj shaft now with no problems.
www.xjor.org
