Driver Side Rocker rust and Rot - JeepForum.com
post #1 of 5 Old 03-14-2010, 02:45 PM Thread Starter
Lemoncrevice
So I was underneath my 2000 wj the other day doing a routine oil change and noticed a few little rust bubbles in the undercoat on the underside of my rocker panel. I tapped it lightly with the end of my wrench and the rocker crumbled to bits i continued looking along the rocker and noticed that the rust is covering aboutt 65% of the rocker and clearly in need of a fix.
This is where i came to you guys for help, I was wondering what i should do next?
I was thinking the the first cutting away any and all rust in rot from the rocker to prevent it from spreading. but of course i cannot leave this open cavity and im not thinking a giant tub of bondo is really what i am looking for. So any suggestions that might not require me to weld in a new rocker all together?
Thanks,
and i forgot to mention also when wheeling the other day i managed to get a pretty decent dent in the same rocker so rocker gaurds/ rock sliders are soon to be on the way
-2000 Jeep grand Cherokee Limited(Rock Star)- Rusty's 4.5" Advanced Lift (sold)
-2002 Jeep Wrangler Sport- RE 3.5" superflex kit
Lemoncrevice is offline
post #2 of 5 Old 03-14-2010, 04:27 PM
Technohead
Instead of repairing the rockers and then getting sliders you can cut the rockers off completely and replace them with (custom) rocker sliders. Lots of guys have done this and you save yourself at least a couple inches of clearance compared to the traditional bolt-on sliders.
-Eric
Technohead is offline
post #3 of 5 Old 03-14-2010, 05:29 PM
lateralus3
1994 ZJ
ah good old new england rust
Jacob
1994 grand cherokee laredo 4.0 IRO 5.5 critical path long arm kit and OTK steering 35x12.50x15 BFG KM2's
high pinion dana 30 and 8.8 in garage
FOR SALE ONE SET OF ZJ D44A AXLE SHAFTS $150 SHIPPED
lateralus3 is offline
post #4 of 5 Old 03-14-2010, 11:31 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Weld in rock sliders or weld in new rockers. Those are your only repair choices.
This isn't going to be fixed with tin, rivets, and bondo.
ratmonkey is offline
post #5 of 5 Old 03-15-2010, 12:57 PM
ruggedscotsman
2007 WK
i came across the same thing on mine when dealing with failing brake lines. If you search rocker here and on mallcrawlin you'll find a number of great threads showing how some people have fixed the problem.
ruggedscotsman is offline
Why in the world is the passenger side hot and the driverís side cool??? red5ive WJ Grand Cherokee Forum 4 03-10-2010 11:54 AM
Rust hole in rocker panel. How much to fix? Zoso ZJ Grand Cherokee Forum 0 06-24-2008 01:17 PM
Driver side stereo sound quieter than pass. side mrbell83 ZJ Grand Cherokee Forum 0 05-20-2008 07:45 PM
Driver Side Window.... CBlakeNS ZJ Grand Cherokee Forum 10 02-20-2006 06:33 PM
help!!! passanger side heater vents not as strop as driver side 2002jeep ZJ Grand Cherokee Forum 4 02-03-2005 11:13 AM
