driver side dash speaker cuts in and out - JeepForum.com
post #1 of 3 Old 07-12-2013, 09:44 AM Thread Starter
Jrboarder27
Happens while turning or hitting bumps. I've checked the speaker, amp, and stereo (stock RBN) connections and all seems good are there any others that I'm missing
Jrboarder27 is offline
post #2 of 3 Old 07-12-2013, 01:54 PM
rdkendrick
2003 WJ
Might be inside the speaker, you may try swapping right to left and see what happens.
Sent from my iPad using Forum Runner
rdkendrick is offline
post #3 of 3 Old 07-15-2013, 09:27 PM
turrillas
try this
at park, turn the stereo on.
Bring all the way down the treble, and turn all the way up the bass.
find a hip hop station, or look for a song with lots of bass, turn the sound up. if the sound cuts off, than is the speaker has a broken wire from the bobine that is inside or the Outside wire that goes from the connector to the speaker is damage (Usually gets broken at the edfe of the speaker or the side of the connector terminals.
If the sound of the speaker does not cut off, than you might have a wire that is broken and making a false contact.
turrillas is offline
