Driver mirror goes left-right but not up-down - JeepForum.com
post #1 of 7 Old 08-19-2017, 01:41 PM Thread Starter
gizmosmith
Grand Cherokee 2012 Overland
I took the glass off the mirror to see the motor behind. I can see it move left and right and hear it while it does so. I can't hear any motor strain or anything when I try to go up and down. Just, nothing.
I took the button control pad out of the arm rest and took it apart. Everything looks good there.
Are there other troubleshooting steps I can try? Is the left-right separately fused from the up-down?
gizmosmith is offline
post #2 of 7 Old 08-19-2017, 02:43 PM
skipperau
Did you check the switch with a multimeter? It's possible for the contacts to be dirty/carboned up without any external signs.
Sent from my iPad using Tapatalk
skipperau is offline
post #3 of 7 Old 08-19-2017, 03:22 PM Thread Starter
gizmosmith
Is there a pinout diagram or schematic for it I could use to check it out?
post #4 of 7 Old 08-19-2017, 03:25 PM
sdjp
sdjp's Avatar
I'd check the condition of the wiring in the crux of door going from the body to the door just as a precaution. Then I'd pull the door panel (look on WJ jeeps for an exact how to), and use a multimeter to check and track where the wiring stops sending power, or if the motor blew somehow, etc.
sdjp is offline
post #5 of 7 Old 08-19-2017, 03:42 PM
sdjp
sdjp's Avatar
There are pin diagrams online if you Google around; just be aware there are some slight variations on certain year/ model WJ's, so just be sure you're looking at the right one.
If you haven't opened the door panel before; it can look intimidating with all the wiring but after checking for a break in the door crux wiring (pull back the black rubber boot and inspect wires...be warned it's a bit of a pain to get back on) my first go to would be the wiring from the side view mirror to the plug that is directly underneath your window controls.
Keep troubleshooting and you'll find the source, it's not black magic. Hopefully just a loose or dusty connection, or a broken wire that needs a splice. Good luck.
sdjp is offline
post #6 of 7 Old 08-19-2017, 06:32 PM
99SK04GTX
At least rolling down the window and applying finger pressure to locate it correctly is easily accomplished.
99SK04GTX is offline
post #7 of 7 Old 08-19-2017, 11:04 PM
fastblack
2012? Try asking around in the WK2 section of the forum. Might be a common problem with that era Grand Cherokees.
Sent from my iPhone using Tapatalk
fastblack is offline
