Driver Door Electrical Problem - JeepForum.com
post #1 of 5 Old 09-28-2013, 11:10 PM Thread Starter
SirSilvia
Wj Driver Door Electrical Problem
Just bought a 2002 WJ limited v8 and starting to sort out the little things it needs.
One issue is that the driver door switches do not work when opened at certain angles.
Lets say the door opens about 70 and the mid resting point is around 50. When closed, the switches all work fine, and they work when opened till about 25. Then fail to work till about 45 and fail to work the rest of the way.
I'm not sure if its some pinched wires, a loose harness connector, or what.
Any info would be great.
2002 Jeep Grand Cherokee Limited V8
SirSilvia is offline
post #2 of 5 Old 09-28-2013, 11:16 PM
bradywgn71
bradywgn71's Avatar
Broken wires in the rubber door boot. Use the search function and you'll find many threads on it because it's a common issue.
2002 WJ Overland - 4.7HO - 231tc - 6" Clayton - 285/75-16 Cooper STT - ProComp 5129 wheels - Kevin's Offroad Belly Skid and Rock Sliders - JKS Track Bar and Disconnects - ProtoFab bumpers
bradywgn71 is offline
post #3 of 5 Old 09-28-2013, 11:46 PM Thread Starter
SirSilvia
cool, was hoping I didn't have to eff with the wiring and may just be the connector. Thanks
post #4 of 5 Old 09-29-2013, 09:13 AM
StormChaserTim
It's not just the connector. There's a ground wire that runs through that conduit from the door into the car. No biggie to put back together. I personally like to splice a small piece of wire in to legthen it to give it some extra leeway.
Tim
1995 Jeep Grand Cherokee Laredo, 4.0L 2WD, 355,000 miles.
StormChaserTim is offline
post #5 of 5 Old 09-29-2013, 10:08 AM Thread Starter
SirSilvia
Tim
thanks for the info
