Drain oil regular way or use a extractor? - JeepForum.com
 3Likes
post #1 of 19 Old 05-19-2017, 10:10 AM Thread Starter
steve_80
I saw this thing in a local store and someone said this works better as it gets all the junk out of the bottom of the oil pan that a normal draining misses.
I assume it sucks the oil out the dipstick?
https://www.princessauto.com/en/deta...or/A-p8469512e
has anyone used one before? Would it actually get more out than using the oil drain plug?
steve_80 is offline
post #2 of 19 Old 05-19-2017, 10:31 AM
uglybastard
I use an extractor on my other car - its a clean but tedious process. If you go this route make sure you get one that can handle the entire capacity of a WJ (6qt).
I've been considering trying out a fumoto valve on my WJ with my next oil change:
https://www.amazon.com/dp/B003VC7138...I3PV3EPZ7K96GZ
I do no off-roading with my WJ so im not so worried about hitting the thing - if that's you, this might not work out so well.
Just a VW guy in a Jeep forum
uglybastard is offline
post #3 of 19 Old 05-19-2017, 10:34 AM Thread Starter
steve_80
but wouldn't that valve the be same as using the drain? I don't mind using the plug as i never get oil on me or my tools.
I thought the pump would get more of the grit out.
steve_80 is offline
post #4 of 19 Old 05-19-2017, 10:40 AM
sdg3205
There probably is next to no sludge in your oil pan anyway Steve. When i did my engine rebuild i dropped the oil pan and was surprised to see how clean it was. Modern oils are pretty clean, and if you've kept up with your oil intervals like my Jeep has had or run synthetics, you're probably fine.
There was a tiny bit of sludge right where the pan dips for the drain, but other than that it was spotless, even the pump pick up screen.
steve_80 likes this.
sdg3205 is offline
post #5 of 19 Old 05-19-2017, 10:44 AM Thread Starter
steve_80
ok good, thanks, saves me $20
steve_80 is offline
post #6 of 19 Old 05-19-2017, 11:31 AM
Jeeples
Jeeples's Avatar
Agreed.
I've dropped both the pans on my 4.7's (which many deem to be a sludge prone engine) and noted no noticeable build up or sludge with each having 150K and 183K on them, this includes my '00 which I have no prior maintenance history on. Same goes for under the valve covers.
Even if the previous owners only went to the local quick lube place every 3K miles the positive in that is the engine oil generally always hot when drained. This generally means the contaminants in oil are held suspension rather than settled at the bottom of the pan.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #7 of 19 Old 05-19-2017, 11:57 AM Thread Starter
steve_80
ok thanks!
steve_80 is offline
post #8 of 19 Old 05-19-2017, 12:12 PM
wjjeep19
Originally Posted by Jeeples View Post
Agreed.
Always on point, Jeeples.
I would save my money and do the regular way. Changing oil on the 4.7 shouldn't be hard. The only time I would justify using an extractor is if the oil change process was too time consuming.
2002 4.Slow
2.5" lift
Software Engineer
wjjeep19 is offline
post #9 of 19 Old 05-19-2017, 12:18 PM
jay-h
I really doubt those devices will work better than the drain plug which is right at the bottom of the pan anyhow.
It is potentially useful fro draining stuff that does not have a real drain plug, however.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #10 of 19 Old 05-19-2017, 12:29 PM Thread Starter
steve_80
yeah i know, the plug is easy and clean. just someone told me that this gets more gunk out :P
steve_80 is offline
post #11 of 19 Old 05-19-2017, 01:00 PM
sdg3205
Was it a Nigerian prince that just needed a few thousand dollars to free up a few million?!
ggullifordjr likes this.
sdg3205 is offline
post #12 of 19 Old 05-19-2017, 01:44 PM Thread Starter
steve_80
yes and his name was steve/david. funny name for a Nigerian prince.
steve_80 is offline
post #13 of 19 Old 05-19-2017, 01:51 PM
ChrisHager
Administrator
ChrisHager's Avatar
I could see tasks where a pump like this would be handy but an oil change is not one of them.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #14 of 19 Old 05-19-2017, 01:54 PM Thread Starter
steve_80
would it be useful to make a transmission fluid/filter change a little cleaner? I don't have the pan with the drain hole.
steve_80 is offline
post #15 of 19 Old 05-19-2017, 02:00 PM
ChrisHager
Administrator
ChrisHager's Avatar
Yup!
You could pump out some of the old fluid before you dropped the pan to change the filter. You could also use this for a quick differential fluid change, though I typically like to inspect the gears when I do a diff fluid change.
This would also be handy for extracting brake fluid, power steering fluid, and other random things that aren't designed to be easily changed. Granted, a turkey baster also works.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
