Drag link question - JeepForum.com
post #1 of 12 Old 09-02-2013, 03:28 PM Thread Starter
AIRBORNE
Drag link question
We cannot seem to get the driver end of the drag link to release from the Pittman arm. I tried prying. I even ground out metal inside the fender well and we were using a normal pry bar on top of the TRE (on top of the threaded part). Also tried a fork and hammer while using the long pry bar. No dice.
Any thoughts?
2000 Grand Cherokee Limited/ Quadra Drive / 4.0L/ OME HD springs, Bilsteins, JKS trackbar, 255/75/17 BFG M/T with JK Moabs
2005 Silverado 2500 HD Duramax
United States Army (2004-present)
AIRBORNE is offline
post #2 of 12 Old 09-02-2013, 03:44 PM
nickblack
pound the part of the pitman arm where the drag link goes into. Not the drag link. Use a BIG HAMMER. If that doesn't work, use some heat on the pitman arm and pound again. You might want to use a mixture of acetone and transmission fluid and soak it down overnight if the above fails. It's probably just rusted in there.
nickblack is offline
post #3 of 12 Old 09-02-2013, 03:54 PM
Olese
What he said. Maybe a couple of soakings of PB Blaster.
Olese is offline
post #4 of 12 Old 09-02-2013, 04:05 PM Thread Starter
AIRBORNE
Thanks for the advice. I was thinking of removing the large but that holds the pitman arm and drop it down. Then I could get a solid blow on the top of the threade part of the TRE. Think that would work?
AIRBORNE is offline
post #5 of 12 Old 09-02-2013, 04:22 PM
nickblack
Bad idea. If you think getting the drag link off the pitman arm, try getting it off the steering gear. It's splined in there. I replaced the steering gear on my WJ and I had it on the bench with a full size sledge hammer and it wouldn't budge. I finally spent the $20 on a new pitman arm. Do what I said above. The transmission fluid and acetone is way better than anything you can buy over the counter. It's an old time solution. I have a spray bottle of the mixture on hand at all times. You will be amazed. Eats thru rust like nothing else.
post #6 of 12 Old 09-02-2013, 04:28 PM Thread Starter
AIRBORNE
I will try that mixture. After popping the hood it appears there is a small opening that I could get a long pipe onto the TRE right near the pitman arm. With a large hammer maybe could budge this thing.
AIRBORNE is offline
post #7 of 12 Old 09-02-2013, 05:02 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Ive never had a problem using a pickle fork and a 3lb sledge...but, only if you are planning on replacing that TRE. If you're planning on reusing it, rent a puller from a parts store.
~James
ezflip is offline
post #8 of 12 Old 09-02-2013, 05:38 PM
js12278
Any reason you don't use a Pitman arm puller? Your can rent them
js12278 is offline
post #9 of 12 Old 09-02-2013, 06:22 PM
Olese
Very important part is what Nickblack said "pound the part of the pitman arm where the drag link goes into. Not the drag link"
Olese is offline
post #10 of 12 Old 09-02-2013, 07:01 PM
nickblack
A good quality puller would do the trick. I snapped 2 Harbor Freight ones trying to remove the Pitman arm from the steering gear but that was a different animal all together. When doing suspension work, always hit the part that the thing you want to remove goes in to, not the part you want to remove.
post #11 of 12 Old 09-02-2013, 07:02 PM
WJomkcin
Yeah what he said, I rented one from Autozone and it was off within 5 minutes of being home
WJomkcin is offline
post #12 of 12 Old 09-03-2013, 08:34 AM Thread Starter
AIRBORNE
Good advice guys. Thank you.
AIRBORNE is offline
