DPA/steering link question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > DPA/steering link question
RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comBUMPERS by Rough Country! SOLD at ROCKRIDGE 4WD!! AWESOME New Wurton LED Pod Lights Brought To JF By Rockridge 4WD!
Unread 08-27-2010, 01:46 PM   #1
Sabotage
I just installed a 3in iro kit on my 02 grand. The lift is awsome, other than the fact that i live in michigan and everything is rusted and was a pain in the *** to take off. But i went to get an alighnment after i did my install, and the mechanic who was gonna do it said he couldnt, becuase the "bar"(i dont think its the draglink) that runs from the pitman arm is all rusty or w.e. Now he also said i need a drop pitman arm so that my steering wheel will alighn back to where it should be. Ill proly buy the IRO 1in DPA IRON ROCK OFF ROAD: WJ Drop Pitman Arm . Now if you guys could help me to make sense of this, and possibly give me a no B.S assesment of what needs to be bought and what dosnt. If possible state where the stuff could be purchased.
P.S i just stuck with the IRO trac bar, i dont have the JKS adjustable. If buying the JKS adjustable trac bar will fix my problems including centering my steering wheel, then just let me know, cus thats a fairly simple solution.
I'm not speeding, i'm qualifying...
Sabotage is offline   Reply With Quote
Unread 08-27-2010, 04:21 PM   #2
skain8
Get some sort of adjustable trackbar whether it be iro, jks etc... No drop pitman arm once you sqP in the adjustable trackbar. Centering the steering wheel is as simple as extending the draglink. If it's rusted and can't be adjusted, that's a minor issue.
'02 WJ: 4.7L, 5", 44/9, 231HD w/SYE, 35's, Clayton's
'99 XJ: stock
'98 XJ: stolen
231HD build guide
skain8 is offline   Reply With Quote
Unread 08-27-2010, 07:38 PM   #3
Sabotage
My draglink is rusted pretty bad. Iv sprayed the hell outta it with no sucess. Any ideas to help loosen the thing up are welcome.
