Door Window switch mod - JeepForum.com
post #1 of 12 Old 05-21-2013, 08:25 PM Thread Starter
scross1220
2012 WK
So today I decided to dive on in and take my door windows switch apart and replace those drab pale almost non eluminated green LED's and install some blue vibrant LED's in their place and add some carbon fiber bling. The install was not to hard and if you know how to use a soldering iron chances are that you can do this mod yourself in no time. Here is a look.
______ooooo
/__l_l_,\____\,___
l_---l_l__l---[o]llllll[o]
_.(o)_)__(o)_)--o-)_)
If you're not fixing it, you're not driving a Jeep.
scross1220 is offline
post #2 of 12 Old 05-22-2013, 07:21 AM
dcorn
Nice. Now figure out a way to make all the window switches auto up and down.
2014 Jeep Grand Cherokee Summit
dcorn is offline
post #3 of 12 Old 05-22-2013, 08:29 AM
Jaketit
How many tries did it take you to wrap it?
Jaketit is offline
post #4 of 12 Old 05-22-2013, 11:48 AM Thread Starter
scross1220
2012 WK
One so far. I used a heat gun after I applied it. The trick also is to use a little water to get it piece in position and the heat gun to set it in place.
______ooooo
/__l_l_,\____\,___
post #5 of 12 Old 05-22-2013, 12:19 PM
A_Cadilli
Very cool! 👍 That CArbon job is flawless. Good work. And really digging the blue. I'd love to switch all my LEDs to white
99 WJ limited 2wd 4.0 STOCK
A_Cadilli is offline
post #6 of 12 Old 05-22-2013, 01:17 PM
ZB_WJ
Nice, except there is no write up yet
I think we all just need a beer. :cheers2: (courtesy of ChrisHager)
This forum is a double edge blade, it's saved me thousands in repairs and cost me thousands in mods
ZB_WJ is offline
post #7 of 12 Old 05-22-2013, 06:58 PM Thread Starter
scross1220
2012 WK
I am now working on the writeup. I have to retake the photos with a real camera because I cant get close in with my iPhone. I will have to open my spare switch unit back up to do so. I will tell you that you will need 9 or the 3mm blue or whatever color LED's you want to use. They must be rated to operate between 3.3 and 4.0 volts DC. All of the nine LEDs are soldered into the PCB so care will have to be taken when removing them or you will wreck the PCB. I have found that blue and red works best but there are some green LEDs that are bright enough. All the LED's can be purchased at RadioShack but I like to get mine on eBay because I buy in bulk. When opening the unit just sliding a flat blade screwdriver will suffice but you will need to melt the plactic tabs on the back of the PCB that hold the switch assemble with a slodering iron to get the board free. There are 8 of these tabs that we speak of. You need to take care of not droping the switch tabs that are in the switch assembley becasuse when you remove the switch PCB the tabs will fall out when you turn the assembly over. They are easy to put back but there is a metal tab on the auto window switch which is tricky to put back in if it falls out so make a note on how it is positioned before you take things apart. Asembley is in reverse and besure to remelt the plastic tabs on the back of the switch PCB before you button things up. I promise to do a thorough write up asap I just have to take apart my other unit this week. I will get it out to you all.
______ooooo
/__l_l_,\____\,___
post #8 of 12 Old 05-22-2013, 07:27 PM
ZB_WJ
Ok. Sorry, looking forward to it!
ZB_WJ is offline
post #9 of 12 Old 05-22-2013, 07:47 PM Thread Starter
scross1220
2012 WK
Promise
______ooooo
/__l_l_,\____\,___
post #10 of 12 Old 01-17-2014, 11:23 AM
rdkendrick
2003 WJ
Originally Posted by scross1220 View Post
Promise
Still looking for the write-up. I want to know what LED part number you used in the climate control HU.
If you are just using Radio Shack standard LEDS with no socket, what size did you use?
Sent from my iPad using my fingers
rdkendrick is offline
post #11 of 12 Old 01-17-2014, 05:09 PM
new2site
Thanks rdkendrick for bumping this...never would've saw it... I'm interested in doing this too...mine are as dim as can be right now..
new2site is offline
post #12 of 12 Old 01-17-2014, 06:57 PM
rdkendrick
2003 WJ
Yeah, I guess I will go to Radio Shack and see what kind of LED's they have. It sounds like the door switch is kind of time-consuming. I think I will just stick with the Climate Control for now. I've done the EVIC already. I tried my gauge cluster, but only got some of the individual bulbs done, because it's one of the white-faced gauge panels in an Overland.
