Door Handle Question - JeepForum.com
post #1 of 4 Old 08-06-2011, 10:32 AM Thread Starter
HookEm
I'm planning on painting the handles on my Laredo. Was thinking about taping them or removing them.
Question is: Has anybody every removed them or had them off of a WJ? If so, can the handles come apart into 2 pieces?
I also have the same question to the side view mirrors.
Thanks!
HookEm is offline
post #2 of 4 Old 08-06-2011, 10:46 AM
tjlmbklr
Thanks!
I hope you get your answer. I have 2 handles that have chips in them that were touched up. Are the Laredos the black plastic or are they painted like the Limited's? My mirrors are black plastic with a bit of a texture to them.
If I got around to them I was going to sand/prep and mask off around it. But I am lazy and impatient, oh, and inexperienced too when it comes to body work. So what do I know.
I will be following this thread to see what others suggest.
Good luck!
Bone Stock 2002 Grand Cherokee Limited
4.7L HO, Changed Stock NV247 Quadra-Drive T-case to a 242 Selec-Trac Shifter and all.
Upgraded my rims to 5 Spoke Rogue from '11 Grand Cherokee
tjlmbklr is offline
post #3 of 4 Old 08-06-2011, 11:26 AM
tuglife
Been thinking of doing the same thing! Mine are all scratched and a little worn consistent with their age and I'm blacking out lots of trim so I wanted to hit the handles as well. Considered buying a black set off a Laredo but there's nothing wrong with mine mechanically. Not sure how well paint would hold up with the wear and tear they'll take. I'd definitely take them off to get good coverage. Never done it so not sure how difficult it is.
,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,2004 WJ Overland ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
4.7 HO V8, K&N FIPK, Old Man Emu HD Springs, Bilstien 5100, 31" 255/70/17 Bridgestone Dueler A/T Revo 2, Black JK Moabs, Overland Rock Sliders, Tow Hooks, Westin Brush Guard, GTP Hood Vents, Mopar iPod Integration Kit
tuglife is offline
post #4 of 4 Old 08-06-2011, 12:27 PM
KDog223
I had to remove and replace the handles when I replaced two doors. They come off fairly easy but I didn't try to separate the handle from the base once they were removed.
KDog223 is offline
Interior Door Panel Question jasandalb WJ Grand Cherokee Forum 3 06-13-2011 10:13 PM
Diver 1 and 2 buttons on drivers side door question? Mud_Crazy WJ Grand Cherokee Forum 20 05-29-2011 12:21 AM
Door question dimebag WJ Grand Cherokee Forum 1 05-19-2011 01:53 PM
Blend door motor question? medflynurse WJ Grand Cherokee Forum 4 03-03-2011 07:26 AM
Door Handle Lights gqmdl0617 WJ Grand Cherokee Forum 27 01-07-2011 02:14 PM
