Door check fix? - JeepForum.com
post #1 of 11 Old 11-05-2013, 11:58 PM Thread Starter
LowLyfe
Door check fix?
So ive got the famous door check pop on my drivers side. Ive searched but havent actually found a remedy aside from replacing the whole assembly. The popping is coming from the body side pin, i tried to grease it but it didnt change it at all. Any home remedies I can try before spending half a bill for the ridiculously over priced assembly?
02' Jeep WJ Limited Edition - Stock height on Hankook Dynapro ATM RF10's 235/65/17
LowLyfe is offline
post #2 of 11 Old 11-06-2013, 12:14 AM Thread Starter
LowLyfe
Edit: I just found part numbers for the bracket and pin which I will try to find locally first
LowLyfe is offline
post #3 of 11 Old 11-06-2013, 04:38 PM Thread Starter
LowLyfe
My local dodge dealership cannot get the bracket seperate from the door check assembly and want $75 for it. What a ripoff, anywhere I can order just the bracket online?
LowLyfe is offline
post #4 of 11 Old 11-07-2013, 10:26 AM
eajones_01WJ
justforjeeps.com used to have them. thats where i had to get mine a few months back
eajones_01WJ is offline
post #5 of 11 Old 11-07-2013, 10:55 AM
rdkendrick
2003 WJ
Have you checked the classified section or a junkyard for one that might be in better shape?
Sent from my iPad using my fingers
rdkendrick is offline
post #6 of 11 Old 11-07-2013, 09:37 PM Thread Starter
LowLyfe
Justforjeeps doesnt seem to have the bracket seperate unless Im not looking under the right section.
Ill look in the classifieds but I have a feeling thats only a temporary fix.
LowLyfe is offline
post #7 of 11 Old 11-07-2013, 09:54 PM
gcjeeping
gcjeeping's Avatar
I thought everyone has a dozen of these. I do. LOL Got 10 more still in the doors in the garage.
_____________
gcjeeping is offline
post #8 of 11 Old 11-08-2013, 01:24 AM Thread Starter
LowLyfe
Hmm are you willing to let just a bracket and pin set go? Or did you just post them to rub it in? haha
LowLyfe is offline
post #9 of 11 Old 11-08-2013, 02:52 PM
gcjeeping
gcjeeping's Avatar
What part is the bracket and pin? The hinge part at the end with the rivet?
_____________
post #10 of 11 Old 11-08-2013, 07:48 PM Thread Starter
LowLyfe
Yeah the end with the 2 bolt holes and the "rivet" which I believe is the pin.
LowLyfe is offline
post #11 of 11 Old 11-08-2013, 07:52 PM
gcjeeping
gcjeeping's Avatar
All the ones I have are riveted. So you'd have to cut rivet off a still have to replace it. Better off just getting the whole assy.
_____________
