-   WJ Grand Cherokee Forum (http://www.jeepforum.com/forum/f310/)
-   -   Door check fix? (http://www.jeepforum.com/forum/f310/door-check-fix-1762937/)
LowLyfe 11-05-2013 11:58 PM
Door check fix?
So ive got the famous door check pop on my drivers side. Ive searched but havent actually found a remedy aside from replacing the whole assembly. The popping is coming from the body side pin, i tried to grease it but it didnt change it at all. Any home remedies I can try before spending half a bill for the ridiculously over priced assembly?
LowLyfe 11-06-2013 12:14 AM
Edit: I just found part numbers for the bracket and pin which I will try to find locally first
LowLyfe 11-06-2013 04:38 PM
My local dodge dealership cannot get the bracket seperate from the door check assembly and want $75 for it. What a ripoff, anywhere I can order just the bracket online?
eajones_01WJ 11-07-2013 10:26 AM
justforjeeps.com used to have them. thats where i had to get mine a few months back
rdkendrick 11-07-2013 10:55 AM
Have you checked the classified section or a junkyard for one that might be in better shape?
Sent from my iPad using my fingers
LowLyfe 11-07-2013 09:37 PM
Justforjeeps doesnt seem to have the bracket seperate unless Im not looking under the right section.
Ill look in the classifieds but I have a feeling thats only a temporary fix.
gcjeeping 11-07-2013 09:54 PM
I thought everyone has a dozen of these. I do. LOL Got 10 more still in the doors in the garage.
http://i120.photobucket.com/albums/o...ps8d73def1.jpg
LowLyfe 11-08-2013 01:24 AM
Hmm are you willing to let just a bracket and pin set go? Or did you just post them to rub it in? haha
gcjeeping 11-08-2013 02:52 PM
What part is the bracket and pin? The hinge part at the end with the rivet?
LowLyfe 11-08-2013 07:48 PM
Yeah the end with the 2 bolt holes and the "rivet" which I believe is the pin.
gcjeeping 11-08-2013 07:52 PM
All the ones I have are riveted. So you'd have to cut rivet off a still have to replace it. Better off just getting the whole assy.
The time now is 03:33 AM.
