Doetsch tech 8000 shocks? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Doetsch tech 8000 shocks?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line~Artec JK 1 TON SWAP~Advance Adapters SYE Kits
Unread 02-16-2011, 05:48 PM   #1
metalhead
Is anyone using these shocks? Are they good? I am looking at the IRO 3 inch lift and can't afford the bilsteins so are the Doetsch tech shocks good? Also IRO suggested using upper adjustable control arms what do you all think is it necessary? I want to replace my front control arms with the IRO ones mostly because all the bushings are shot and just want better arms.
metalhead is offline   Reply With Quote Quick reply to this message
Unread 02-16-2011, 06:14 PM   #2
skain8
Under Construction
skain8's Avatar
They suck. Get a monotube shock if you want a quality ride.
Tom
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
'99 XJ: stock
'99 XJ: stolen
'06 XK: sold
231HD build guide
skain8 is offline   Reply With Quote Quick reply to this message
Unread 02-16-2011, 07:10 PM   #3
JeepWJ
2003 WJ
I run the Doetsch shocks. They have a bit of a rough ride, and they squeaked for quite a while. Apart from that, they do what they need to do. If I could afford Bilsteins, I would have gotten them, but the Doetsches are passable.
That being said, if I were to do my lift over again, I'd spring for the Bilsteins.
2003 WJ Ltd, 3" IRO w/ OTK + JKS discos, 245/70R17 BFG KM2s, JCR sliders, ProtoFab rear bumper, lots of electrical mods.
my build thread; my Jeep, my Twitter, my blog.
JeepWJ is offline   Reply With Quote Quick reply to this message
Unread 02-16-2011, 07:11 PM   #4
JeepWJ
2003 WJ
nyuk nyuk nyuk
Unread 02-16-2011, 07:14 PM   #5
billzcat1
Chicken in a Turkey Suit
2003 WJ
Shocking!
billzcat1 is offline   Reply With Quote Quick reply to this message
Unread 02-16-2011, 07:22 PM   #6
JeepWJ
2003 WJ
Wow, that put a damper on things..........
Unread 02-16-2011, 09:36 PM   #7
bigV
I don't have any complaints about my DT8000's, not sure why they get so much bad press on here, hydraulic shocks will act like a hydraulic shock. If I were to complain about ride quality, it would be about my mud terrain tires, not my shocks. Adj UCA's aren't necessary with a 3" lift (IMO)
www.hd4w.org
High Desert 4 Wheelers
bigV is offline   Reply With Quote Quick reply to this message
Unread 02-17-2011, 05:22 AM   #8
Androoos
I read all over the place (here and other forums) that DoetschTech are junk. Very squeaky and a hard ride. Monotubes really are the way to go. If you look hard enough you can find the Bilstein 5100s for around $75 per shock shipped. They aren't that much more considering how much better they are.
2001 Jeep Grand Cherokee Limited 4.7L Selec-Trac: 2" Fat Bob's/BDS Coil Lift, Bilstein 5100 Monotubes, JKS Quick Discos, Rough Country 2.2 Steering Stabilizer, OEM Tow Hooks, Kenwood Excelon KDC-X890
Androoos is offline   Reply With Quote Quick reply to this message
Unread 02-17-2011, 06:53 AM   #9
bigV
http://www.4x4xplor.com/DT8000.html
www.hd4w.org
Unread 02-17-2011, 07:05 AM   #10
huntandfish
I really like my DT8000's. Slightly stiffer than the stock shocks but also twice as beefy, not to mention the built in bump stop is a great idea. I dropped a front coil on the trail last trip(something some say cant be done with stock control arms) and a combination of the doetsch tech bumpstop and the wheel spacers is probably what saved me from shredding anything.
a lot of people that say they are crap are compairing them to shocks that cost twice as much or more. Really, they flex great and are built very sturdy.
with the DT8000's and the Addco rear sway bar my wj corners back roads like a sports car. I dont worry about blowing one on a bad pot hole. I hit a nasty shallow ditch going way too fast and they came out alright. i only hat time to say "oh shi"BOOOM.
1992 YJ 2.5 SOLD
2004 Grand Cherokee Special Edition 4.0
IRO 3",JKS BPE's,DoetschTech8000's,Tenneco SS,Cooper Discoverer STT's 245-75R16,RC wheel spacers,SSBC Slotted Rotors, IRO Prem-sliders...
A great place for outdoorsmen in the NW. www.hunting-washington.com Member Screen name- addicted
huntandfish is offline   Reply With Quote Quick reply to this message
Unread 02-17-2011, 07:57 AM   #11
jackadf
Junior Member
I had the DT8000's, thought they rode too rough for me and they sqeaked real bad when it got cold. Switched to Bilstien's and the ride is much better and no more sqeak.
jackadf is offline   Reply With Quote Quick reply to this message
Unread 02-17-2011, 08:40 AM   #12
Capricorn
I've got a buddy with a GC on a 6" lift running Bilsteins and said the ride quality is superb, so I coughed it up and got the Bilsteins with the IRO 3". Should be in tomorrow. I heard mixed reviews about the DT8000's, so I guess we'll see how they ride.
2002 Grand Cherokee Limited
4.7L Powertech V8 l Iron Rock Offroad 3" Suspension Lift l Bilstein 5125 Shocks l Bilstein 5100 Steering Stabilizer l 17x8 Unique Steel Wheels l LT255/75R17 BFGoodrich Mud Terrain KM l Kevins Offroad Transfer Case Skid l Kevins Offroad Roof Rack Tire Carrier l Hella 500 Black Magic
http://ddoffroad.com
Capricorn is offline   Reply With Quote Quick reply to this message
Unread 02-17-2011, 04:45 PM   #13
metalhead
Thanks for all the replies. Guess I will have to wait a little longer to get the lift and save for the bilsteins.
Unread 02-17-2011, 09:30 PM   #14
Capricorn
Once I get my lift with the Bilsteins in, I'll get a pic in...actually, once I install the lift, then I'll let you know how they ride.
Unread 02-17-2011, 09:51 PM   #15
WJChris
WJChris's Avatar
they are rated for a much heavier truck. They were so stiff that over speed bumps, it allowed my tires to leave the ground at more than 6 MPH.
Spend the extra, you will end up changing them out anyway.
My Rubicon Express have been real nice.
WJChris is offline   Reply With Quote Quick reply to this message
