Does this sound like a trasfer case problem? - JeepForum.com
post #1 of 38 Old 03-14-2014, 11:40 PM Thread Starter
wj47ho2004
My 04 w/ 4.7ho and 247 quadra trac 2 has only 68k. Coming back from a trip 30 miles highway speed I took a shortcut on a road with a 15
mph speed limit. All of a sudden, it "sounded" like my tires were rubbing the fenders with a slight metallic sound and the jeep bogged down some. It got quiet after about a mile.
Pulled in garage and changed the Tcase with more oem special fluid and rear diff fluid was also changed. The tcase had a few very small metal parts but the rear diff fluid did have alot of fine metal. i did find a front tire was 6psi low and on full time awd not a good idea. On initial test drive it "popped" twice and jerked. I took it out twice after that letting it cool down in between. The diffs and tcase were warm but not hot and it didn't make any sounds in about an hour of driving slow to 60mph. I took it 25 miles round trip to work and it didn't make any noise the next day, maybe a slight vibration but it could be me. I'm not the really that lucky that a fluid change
fixed everything...or am I? The fluids were first changed when I got the jeep in 2007 with 43k miles. The roads were mostly straight so the viscous coupling and all would be all spinning the same rate. It was bogged down going straight, no turns. What could bind going straight?
Did the tcase fluid maybe break down? I saw some people say that happens. I really cant afford a new rebuilt tcase at the moment but am willing once I
prepare emotionally and money wise. I checked front diff fluid too, good level and color.
What part of the tcase could be making that sound if thats what it really is?
Any opinions on life left on it etc from someone of
experience would be appreciated. Thanks!
wj47ho2004 is offline
post #2 of 38 Old 03-15-2014, 08:45 AM
MadderThanMax
Did you put Friction Reducer in the TC??
MadderThanMax is offline
post #3 of 38 Old 03-15-2014, 08:55 AM
Turbozcs2003
247 takes mopar fluid.
the diffs take 75-140 with the additive.
How are your u-joints??
Did you change the gear oil in the front diff?
Turbozcs2003 is offline
post #4 of 38 Old 03-15-2014, 11:12 AM
brianestep
As in he should, or shouldn't have put FM in the transfer case?
FM with QT2 (open) diffs? I'm not 100% on that friend
-Brian- 2000 WJ Four liter, 4" RC springs; Bilstein 5100s; JKS trackbar w/KOR bushings; Stillen rotors; KOR (RC) 1.5" wheel spacers; 265/75/16 Treadwright Guard Dogs; Rusty AirTube, Amsoil Cone; Thule M.O.A.B.; Bumper delete; rear seat disco
brianestep is offline
post #5 of 38 Old 03-15-2014, 11:51 AM
Johnyre
No fm for qt2.. just the dealer 247 fluid. qt2 has open axles so no fm either
As I roll down the trail,I hope my traction will not fail.But if I spin & begin to slide,please dear lord protect my ride
https://
http://fortcollinswheelers.com
Johnyre is offline
post #6 of 38 Old 03-15-2014, 12:50 PM
MadderThanMax
[QUOTE=brianestep;21261881]As in he should, or shouldn't have put FM in the transfer case?
what do you think??
post #7 of 38 Old 03-15-2014, 01:38 PM
mtchristman
None in transfer case.
mtchristman is offline
post #8 of 38 Old 03-15-2014, 02:48 PM
Johnyre
None period!! He doesn't have Quadradrive..(vari lock axles)
He has the Quadratrac 2 which just means he has a 247 t-case which uses 247 mopar fluid.
https://
Johnyre is offline
post #9 of 38 Old 03-15-2014, 10:11 PM Thread Starter
wj47ho2004
I have the only fluid recommended for the 247, the oem 5016796AC type. The diffs had mobil 1 syn with the required fm. Now have lucus syn which says does not require fm. It does not chatter. It was a constant rubbing like noise and I had to give a little more throttle to maintain speed. I did not change the front diff fluid, it was clear what ran out. I'm not ruling it out as a culprit but suspect it less. I torqued the driveshafts by hand and they didn't have alot of slack in the u-joints, they were pretty tight. The sound wasn't metal, it was like a loud hum I remember. When I took it out for the test drives I ran my phone on video to get the sound but of it did not reproduce it. I don't want to start throwing money at it because it can get very expensive. I was kinda hoping for something to fail in order to resolve the search but now I'm just nervous about driving it anywhere.
post #10 of 38 Old 03-16-2014, 03:49 AM
shockracer
Have you tried 4 Low? Have you tried driving in a tight circle?
2001 WJ 60th anniversary edition 4.7 quadra-drive
5" hybrid lift, 265/70/17 Guard Dogs load E, bilsteins 5100's, addco sway bars, JKS front quick disco's, JKS adjustable track bar, KOR durometer track bar bushings, IRO crucial path front L.A.s, 1.25" Spidertrax spacers
Colorado Jeep Club Member #262
shockracer is offline
post #11 of 38 Old 03-16-2014, 07:38 AM Thread Starter
wj47ho2004
No I did not try low, I was thinking about it though. I made some circles but not very tight. Ill try to try today. Usually when people see you driving in circles in their parking lot they think you've been drinking and call the police.
post #12 of 38 Old 03-16-2014, 08:10 AM
shockracer
LOL
I'm wondering if the chain in the T-case is stretched.
post #13 of 38 Old 03-16-2014, 09:45 AM
Johnyre
Dude You said you have qudratrac2 not Quadradrive. correct?? Fm is not needed for open axles that QT2 has unlike Quadradrive that has vari lock axles
https://
Johnyre is offline
post #14 of 38 Old 03-16-2014, 12:29 PM
brianestep
[quote=MadderThanMax;21263985]
what do you think??
I think no FM in either diffs or tcase as well.
Before Johnyre has an aneurism
post #15 of 38 Old 03-16-2014, 01:14 PM
Johnyre
[quote=brianestep;21288945]
Lmao! Some people don't listen for the ****
Just trying to save them some money
https://
Johnyre is offline
