Does my cooling system have an air pocket? - JeepForum.com
post #1 of 1 Old 11-02-2011, 05:40 PM Thread Starter
WJhappened
I recently replaced the water pump and thermostat on my '04 4.7.
When I drained the system, I collected about 2 gallons from the system. When I refilled it, it only took about 1.5 gallons. I used the air bleeder when I refilled it. I ran it with the heater on to make sure I circulated that portion, as well.
I expected the system to work some air out over the next couple of days and have to top off the reservoir, but that hasn't happened. My reservoir is actually overfilled now. When I remove the radiator cap, it appears topped off.
So, how could my system have held more fluid before? Could a bad radiator cap make it so the system can't draw fluid from the reservoir?
Amateur mechanic here... thanks for the help.
WJhappened is offline
Cooling system flush vczar1 WJ Grand Cherokee Forum 13 10-05-2014 11:27 AM
Can't keep air out of cooling system Big_C WJ Grand Cherokee Forum 18 10-24-2013 03:08 PM
4.0 Cooling System Problems edub70 WJ Grand Cherokee Forum 6 09-23-2010 10:01 PM
How to air my cooling system ? diogene WJ Grand Cherokee Forum 1 05-21-2010 01:04 AM
What is Going on With My Cooling System? Astorm WJ Grand Cherokee Forum 2 05-06-2004 07:12 PM
