Does It matter wich tre to center steering wheel - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Does It matter wich tre to center steering wheel
The ULTIMATE "Selectable" Locker System! BroughRough Country Lift Kits and Parts!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 08-14-2014, 03:18 PM   #1
TURNER76
Can you adjust both or just the tre at the pittman arm to straighten steering wheel.Will adjusting the tre at the knuckle mess with the alignment?
TURNER76 is offline   Reply With Quote
Unread 08-14-2014, 03:20 PM   #2
PolkaPower
The adjustable sleeve on the drag link centers the steering wheel. The other one is to set your toe.
PolkaPower is offline   Reply With Quote
Unread 08-14-2014, 03:27 PM   #3
TURNER76
Unread 08-14-2014, 03:31 PM   #4
JohnnyV
To adjust centering you'll need to loosen both ends of the upper sleeve ( That attaches to the pitman arm ) and use a pipe wrench or channel locks to rotate the sleeve. You should not mess with anything else.
2002 WJ Limited 4.7L
1995 ZJ Laredo 4.0L
1989 XJ Laredo 4.0L - Sold
JohnnyV is offline   Reply With Quote
Unread 08-14-2014, 03:48 PM   #5
TURNER76
Oh,I always twisted the tre's that should be much easier anyways.So my steering wheel Is off just a little to the left (drivers side)witch way should I turn the bar?
Unread 08-14-2014, 11:15 PM   #6
TURNER76
I've been taken the tre loose and turning them instead of turning the sleeve.so how do you no which direction to turn the sleeve to move the steering wheel left or right?
Unread 08-14-2014, 11:33 PM   #7
99WJ539918
Center your steering wheel, loosen the clamps on the sleeve, and rotate it a little at a time. Then tighten the clamps, start your WJ, turn the steering wheel side to side, center the steering wheel again, and check the tires to make sure it's straight. Repeat if necessary. The last time I did this I had to rotate that sleeve a turn and a half.
PSA - It would be nice if people made an attempt while typing to discuss their problems or opinions instead of one long sentence with no punctuation. Maybe I'm cynical, but that really pisses me off. Rant over.
"It's like saying I had a car I got that was painted by the previous owner. I had an accident so painting a car is unsafe." - cykaaro
99WJ539918 is offline   Reply With Quote
Unread 08-15-2014, 12:28 AM   #8
MuddyWJ
Make sure the pitman arm is pointing towards the drivers front tire.
MuddyWJ is offline   Reply With Quote
Unread 08-15-2014, 05:14 AM   #9
Darnice
http://www.jeepforum.com/forum/f310/...wheel-1529152/
should have made that a sticky.
Darnice is offline   Reply With Quote
Unread 08-15-2014, 07:12 AM   #10
ChrisHager
ChrisHager's Avatar
That seems like a massive amount of work. Why not leave it connected, loosen the clamps on both ends, then turn the rod?
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
Hers: 2000 TJ
ChrisHager's 'Grilled' Thread
WJ Torque Specs
Originally Posted by tommyooooooh View Post
But ChrisHager makes me want to poor water on a burning bucket of gasoline now just out of curiosity.
Originally Posted by billzcat1 View Post
The latest lift kit from Rough Country? :D
Originally Posted by Jeeples View Post
Your symptoms sounds just like what it does when it's not doing what it should because of how it is.
ChrisHager is online now   Reply With Quote
Unread 08-15-2014, 08:07 AM   #11
PolkaPower
Get someone to sit and watch the wheel while you turn the sleeve. Takes ten minutes.
Unread 08-15-2014, 08:32 AM   #12
WXman
Mine takes 3 minutes. Loosen clamps on sleeve, turn bar clockwise if looking at it from driver's wheel toward passenger's wheel, tighten clamps. That moves the steering wheel clockwise. Mine took 3 turns...yours will vary. Simple as pie unless your bolts in the clamps are rusted.
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is online now   Reply With Quote
Unread 08-15-2014, 08:38 AM   #13
ezflip
Theme Park Dinosaur Head
ezflip's Avatar
Originally Posted by Darnice View Post
Added to the FAQ
~James
2002 Overland - 4.7 HO, "Select-Drive", 4" RC long arms, TAG front winch bumper, 32" BFG KM's, Kolak 3" exhaust, Flowmaster 50 series
Build Thread
KCCO
ezflip is offline   Reply With Quote
