Do you have LED tailight bulbs in stock assemblies? - Page 2 - JeepForum.com
post #16 of 22 Old 04-23-2013, 12:51 PM
JimmydaGreek
2015 JK Wrangler
2015 JK Unlimited Rubicon Loaded and Modded
JimmydaGreek is offline
post #17 of 22 Old 05-03-2013, 11:58 PM Thread Starter
ancientspear
Thanks for the tips. I tried one set of bulbs I got for free from a local shop which were quickly returned as their output was half that of the regular style. Then I found some on eBay like the ones you guys recommended for reverse lights and they're great!
Reverse lights = White 3157 CREE Q5 12 SMD LED Car Turn Signal Light Lamp Bulb 7W 12-24V (link)
ancientspear is offline
post #18 of 22 Old 05-04-2013, 05:34 AM
frosty68
Do you need load resistors for any of these lights and if so how and where do you put them?
frosty68 is offline
post #19 of 22 Old 05-04-2013, 11:07 AM Thread Starter
ancientspear
just for turning signals. they effectively trick the computer into thinking the right amount of load is on the circuit. without them, your signals will flash really quick because the computer thinks something is wrong, because LEDs draw less power, and does this to alert you in the cab something is up with your flashers...in theory
i'll let someone else explain installing them, since I have not done so myself
post #20 of 22 Old 05-04-2013, 11:12 AM
ZB_WJ
Resistors are easy to install with quick splices. Just splice the resistor to the power (major) and the turn (minor).
I put them on front for my switchbacks. But rear is the same.
I think we all just need a beer. :cheers2: (courtesy of ChrisHager)
This forum is a double edge blade, it's saved me thousands in repairs and cost me thousands in mods
ZB_WJ is offline
post #21 of 22 Old 09-14-2013, 11:58 PM
carl78
I'm going to upgrade the brake lights with high power led lights from lightingnext. The lights look well-made and are direct drop-in replacements for my 3157's socket. Now what I'm unsure of, is which color to buy. It is my understanding that a red filter (the plastic tail lens in this case) will block out all light except red, but the manufacturer uses a poorly lit yellowish bulb to illuminate the tail lights from the factory. So my question is, if each of the red and white versions of this product produce the same output of light, which will produce better light through the filter, red or white Cree LEDs? I would imagine the ultra-bright white Cree LEDs that I've seen in action would do a fantastic job of illuminating my tail lights, but when I saw the red version it made me stop and think... what if the red would look brighter/better (more red)?
carl78 is offline
post #22 of 22 Old 09-29-2013, 09:19 AM
vanillathrilla
Those look AWESOME! Thanks for the comparison photos.
'99 TJ Sport | Rampage Frameless | 33x12.50x15 Goodyear MTR/K's | Poweraid TBS | Flowmaster 40 series | Herculined | 15% tint | LED interior lighting | AtoZ front/rear bumper | AtoZ tube rocker guards | Kenwood Excelon KDC-X993BT | Kicker 6.5's in soundbar | Alpine Type-R 4x6's in dash.
vanillathrilla is offline
