Do I only need the yoke from the tcase with a front shaft swap? - JeepForum.com
post #1 of 3 Old 03-19-2012, 07:52 PM Thread Starter
ArmedJustice
Wj Do I only need the yoke from the tcase with a front shaft swap?
To start off, I have a 04 WJ 242 Selec-Trac. My front drive shaft has u-joint at axle and CV at the tcase.
I am getting ready to install a 3'' lift and was told that I need to get a shaft that has the u-joints on both ends. If I can find a WJ shaft a the local junk yard, do I just need the yoke from the tcase to make the swap or is there more to it?
I have searched around, but I cant seem to find a definite answer.
ArmedJustice is offline
post #2 of 3 Old 03-19-2012, 08:04 PM
jamesnmandy
I am wondering what year model WJ's have double cardan jointed front shafts. The Repezza joint on my 01 WJ tore up, has a standard ujoint on the axle, same as your's. I would rather go back with a double cardan ujointed shaft, but you have to have an adapter from flange type to ujoint yoke for it to work. I am not lifting mine so I may just get the stock joint rebuilt and move on.
jamesnmandy is offline
post #3 of 3 Old 03-20-2012, 08:14 AM
StrokedWJ
StrokedWJ's Avatar
Go to car-part.com and search for a WJ 4.7L front drive shaft with u-joints at both ends. Then, yes you'll need the u-joint yoke to replace the front output yoke on the TC.
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
front yoke swap on 242, any tips? MEinSoCal WJ Grand Cherokee Forum 17 09-06-2011 04:30 PM
front DS and tcase yoke ? thestig_wj WJ Grand Cherokee Forum 10 06-09-2011 12:36 PM
Tcase swap Phoenix1120 WJ Grand Cherokee Forum 1 03-02-2011 06:49 PM
WTB- u-joint yoke for 242 tcase BransJeep WJ Grand Cherokee Forum 4 01-25-2011 10:08 PM
