Do I need a new PCM? - JeepForum.com
post #1 of 11 Old 06-19-2013, 11:17 AM Thread Starter
wgripp
Ladies and Gentlemen,
My WJ is displaying the check engine light and throwing error code P0601. Reasearch has led me to believe the only way this can be fixed is by replacing the PCM. I would rather not do this as it is a $200 fix.
My MPGs have not decreased. My engine seems to be running just as well as before the error code.
Is there any benefit to replacing the PCM besides losing the check engine light?
Can I just pick up a junkyard PCM, or does it need to be professionally reprogrammed with my VIN (or some other crazy stuff)?
Thanks!
Bill
wgripp is offline
post #2 of 11 Old 06-19-2013, 01:29 PM
ChrisHager
Administrator
ChrisHager's Avatar
I did a little research and found many people cure the code by replacing the PCM. I can't really answer your other questions but thought I'd verify what you've found. Being that you have no driveability issues, have you tried disconnecting the battery for a half hour to see if it clears the code? If it comes back, you'll know it's probably there to stay.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #3 of 11 Old 06-19-2013, 06:16 PM
aleet25
2003 WJ
$200 fix?!?! Where are you finding a new PCM for $200? I had to replace mine(and it does need to be programmed) for $900!
aleet25 is offline
post #4 of 11 Old 06-19-2013, 06:23 PM
uberjon
You must think its a dealership only part. I bought mine for like 140 $ from either auto zone or advance auto.
uberjon is offline
post #5 of 11 Old 06-19-2013, 07:40 PM
perfeng702
I got mine from one of the online refurb places for around $200 also. Comes with a lifetime warranty. Just have to give them your vin and mileage so they can program it.
1999 WJ 4.7, 242HD, IRO 4" Long Arm, IRO Adj Track Bar, JKS BPE, JKS Quick Disco, 15" Cragar D-Window, 32" BFG KM2, V3 Projectors, DDM Tuning 55w 5k HIDs
perfeng702 is offline
post #6 of 11 Old 06-19-2013, 08:25 PM
HOSTED67
If the car runs fine and you do not have emission inspections in your area than I say it's up to you to decide if it's worth it to replace it. Personnaly, I would drive it, but I don't like working on my own cars unless I have to.
ASE Certified Master Automobile Technician and Master Truck Technician
HOSTED67 is offline
post #7 of 11 Old 06-20-2013, 06:17 AM
Jersey4Jeeps
2003 WJ
2003 WJ here - same code, my check engine light came on 14 mo. ago and after 16K miles still runs perfect.
AutoZone report said internal fault - ECM unable to communicate on the SPI line
probable causes:
-shorted input sensor
-shorted electrical circuit
-failed ECM
not sure what those things mean or if they can be diagnosed and fixed without replacing the PCM. others care to chime in. thanks!
Jersey4Jeeps is offline
post #8 of 11 Old 06-20-2013, 11:04 AM Thread Starter
wgripp
Jersey4Jeeps,
Shorted input sensor and electrical circut sound much easier to fix than the whole PCM!
wgripp is offline
post #9 of 11 Old 06-20-2013, 01:55 PM Thread Starter
wgripp
Jersey4Jeeps, whats your MPG? I dont drive on the highway, and typically get 15 or so.
wgripp is offline
post #10 of 11 Old 06-20-2013, 04:23 PM
JoeFaz
KL Cherokee
I'm wondering the same thing. (Needing a PCM). I have this incessant erratic idle problem. I have had all the sensors which could possibly effect the idle changed, and it still happens. My go-to mechanic is at a loss (and he's a LONG TIME Jeep only guy), says there are gremlins in the electrical system that he simply can not locate/eradicate. As an aside, I changed the oil sending unit as I would ocassionally get a "0 pressure" reading. Bad unit, broke apart when removed. NOW...I get a "P0523" code (sending unit problem)! AND I STILL have this awful idle problem with no codes at all related to any other sensors or idle issues!
OK, I guess I'm just venting, but this is driving me crazy. Anyone interested in a '99 loaded, gorgeous GC Limited with 67K?
JoeFaz is offline
post #11 of 11 Old 06-20-2013, 06:06 PM
Jersey4Jeeps
2003 WJ
consistently get 17 on both 2003 and 1998 str. 6
